Results 1 to 2 of 2
Thread: Winamp not saving my EQ
    Jun 2008
    Am I missing some setting in RR to make it save me EQ setup. Everytime I restart RR I have to go back in and adjust everything along with my line in volume for my XM it keeps going all the way back down and I have to turn it back up. My skin I am using is Simplistique and it doesnt have anything like a save EQ button.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    FIRST: Make sure you're not using winamp LITE or you could get some weird issues. Other than that, RR doesn't change/save EQ settings -- just shows what's on winamp, so you should run winamp alone (no RR) and see if whatever you set stays when closing and re-opening it -- if not, then you need to see what's causing it to loose its settings, maybe remove and re-install it. For your XM volume, how do you get the XM audio in ? through an audio line ? If so, you may want to check the map master volume in RRConfig -- set it to MASTER. Also try changing the output plugin in winamp between directshow and waveout to see if it helps.
    Ride Runner RR's Myspace
  1. WinAMP 5 Comes to front on launch
    By macbrando in forum Road Runner
    Last Post: 09-05-2007, 09:01 PM
  2. Digital Crossover and EQ
    By spoonraker in forum Car Audio
    Last Post: 03-18-2007, 10:50 PM
  3. Winamp volume problems
    By froop in forum Road Runner
    Last Post: 09-17-2005, 12:02 PM
  4. No more winamp EQ problems!! (for lorty users)
    By embedded in forum Software & Software Development
    Last Post: 03-28-2001, 03:16 AM
  5. Winamp EQ Control
    By Brain in forum General Hardware Discussion
    Last Post: 02-29-2000, 08:31 PM
