Results 1 to 6 of 6
Thread: Retrieving Info From External App To RideRunner
    Oct 2004
    Israel
    hi all
    im wondering if there is a way of retrieving info from an external program to rr
    the app is m4-atx configuration program
    its a simple vb app
    i want to get the voltages textboxes into rr labels
    i can get their class id's , texts and everything with autoit window info
    so im guessing there must be a way for it to be read by rr
    is it possible?
    thanks in advance ,
    madboy
    HeadUnit : Car-Pc | Processor : JBL MS-8 | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Tang-Band Ceramic 25-1719S | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI , SPL AB03445 | Wiring : Sommer , Neutrik
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you can read it somehow (i.e. autoit), then it is definitely possible to make a (extension) plugin to display the info in RR. If you have the source code for the vb6 application then it would make it a lot easier, but if you already know autoit and can read the values from the app, you just need to make a script that reads the values say every second and sends them to RR using the sample scripts attached.
    Attached Files Attached Files
    Ride Runner RR's Myspace
    Oct 2004
    Israel
    thanks guino ,
    ill try to request the source from the m4 guys but its unlikely they will give it away
    i don't know autoit that much hehe
    and its been a while since ive codded with vb :\
    how do i read the values from within autoit? i went over their documentation and i can see only how to control the "controls" , the question is how to retrieve their "text" not write to it
    first ill try to contact m4 guys and lets see what happens
    i hope that if ill get the source someone will be able to do this
    thanks again
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    i believe when the m4 first came out the released an sdk which allowed for plugin type creation. I remember i was gonna make a RR extension plugin for the m4.. but the reliability issues at the time changed that plan lol
    Live mp3Car Facebook Chat
    Oct 2004
    Israel
    well i have no problems with the m4 so far
    any chance you track the sdk ? i couldn't find it..
    still nothing for mini-box guys..
    Jun 2003
    Memphis - TN
    You can embed their application...
    After messing around with it, I was able to find out the window title.
    its "M4AtxTitle"
    "LOAD;m4.SKIN;M4AtxTitle;c:\Program Files\Mini-Box.Com\M4ATX\M4AtxTray.exe;M4AtxTitle",
    As a test I created a skin file called m4.skin, which embeds the tray application.
    I have also created a skin file which uses larger text and a black bakground.
    Just unzip these two files into the the c:\Program Files\Mini-Box.Com\M4ATX\ directory.
    Choose the skin "Big(custommx3)"
    I have attached a screenshot.
    Also you can edit the mbs file with notepad and change colors. You can also change the BMP to whatever you like. I know its not a plugin, but at leasts it will embed.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  1. Invalid Argument
    By tn6478 in forum StreetDeck
    Last Post: 12-30-2007, 09:02 PM
  2. Alpine City Cruise
    By Hell-Stopper in forum RR Skins
    Last Post: 02-22-2007, 11:05 PM
  3. 1.0.4.7 bug
    By debugger in forum StreetDeck
    Last Post: 07-01-2006, 04:01 AM
  4. External App Problem
    By scott011422 in forum Media Engine
    Last Post: 03-08-2005, 03:28 PM
  5. XM PCR External App
    By dug1967 in forum MediaCar
    Last Post: 08-04-2004, 11:35 AM
