Page 1 of 8 12345678 LastLast
Results 1 to 10 of 79
Thread: RR 08-01-2009 Release (Updated: 8/21)
    MySQL Error
    Oct 2004
    Arrow RR 08-01-2009 Release (Updated: 8/21)
    Available NOW (www.nisuautomotive.com) -- UPDATED 8/21/09
    DLINK USERS WARNING: There's was NO TESTING for the DLink radio on this release -- we have not been answered by any DLink users to help test the implementation for the DLink radio. If you're a DLink user: we would like your help, please contact us for testing.
    September's release is already in progress...
    Thanks for your support,
    Guino.
    after installing this NEW release of RideRunner, please run RRConfig and chose your radio type... or edit rr.ini
    "radiomode=" has been depreciated, for a better easier to read method
    "radio="
    Available at release:
    radio=HDRadio
    radio=SiLabs
    radio=HQCT
    radio=RadioShark
    radio=Blaupunkt
    radio=WinTV
    there are a bunch of updates too, some Highlights:
    Guino: code to improve unicode support
    Guino: removed mappoint code from code, its now a plugin!
    BlueZX3: removed the weather code from core, and its now a plugin!!!
    also there will be some new documentation, please check the documentation directory
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = bug fix
    ^ = Note
    8/15/09
    # RRConfig, Reset TV list dropdown missing list...duh
    8/4/09
    + Improved WRITETOFILE and ADDTOFILE commands to work with ++ to save || to files
    + USERVAR: "RRArtPath" (points to rr root, for now, possible change coming)
    8/2/09
    # picviewer.skin, path for pictures was not set
    + Improved Unicode Support for iLists and Scroll Labels
    + Improved Unicode Support for WMA and MP3 tags
    * Changed from \n to <crlf> for end of line in label
    8/2/09
    + SKINCOMMAND: "ClickInd" - This allows to create a button to "click" a indicator (main uses would be SDK or poorly writtin ext plugin)
    8/1/09
    - Weather module from core
    7/31/09
    * Improved Indicator Support so it will always redraw when over buttons or sliders.
    * Improved Scroll Labels so they can be placed/used over BUTTONS, INDICATORS and SLIDERS
    7/29/09
    ! Rewrite of resume.ini file structure (its NOW A STANDARD .INI type) (not backward compatable, delete it, if you use old riderunner)
    + SKINCOMMAND: "titlemenu"  for DVD (currently supported in MPC)
    7/24/09
    - Removed Mappoint code from RR Core
    + Created Mappoint Plugin
    * Readings of GPS/Temps/Volts are taken more often
    + Added GPS.TXT support for simulating GPS with saved data log
    # Fixed small issue with navigation sequence in some rare cases
    # Fixed OSK sometimes showing no window behind it
    7/22/09
    + Small addition for HORM, rr now sees how if windows session has ended, and does HORM save functions
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Is it possible to work on the ONEXIT command. I seen a thread from 2007 that showed that Guino had added this. But recently this doesnt seem to be working.
    Thanks in advance for the work
    New Age Garmin - Skin for RR
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    Mitch, are you guys seeing noticeable performance improvement these days with the RR core as you pull more stuff out of it and into plugins? Performance hasn't been an issue for me, just curious.
    Thanks for the great work guys!
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    does that mean i can't use my Cinergy radio anymore??
    MySQL Error
    Oct 2004
    Quote Originally Posted by Nomader View Post
    for you, i wouldnt update, till i get the module for it done
    id love to have one of these radios in hand... from what i hear
    they are rare and hard to get...
    even if i code the module, it will be impossible for me to test, without the tuner, i could use your help to test... you might be the only one actively using it
    i do know, ill try to get the basics done for it 1st
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    Quote Originally Posted by Zogg View Post
    i got a fast pc, and havent noticed anything performance wise, i dont expect to see and performance change, the radios never really used that much cpu%
    its just a cleaner core of code...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Apr 2006
    Greece
    Quote Originally Posted by mitchjs View Post
    i wonder what i am going to do when i will start getting the nag screen..They are indeed rare, but in my opinion are one of the best. i remember guino used to have one (i think). of course i will help..
    MySQL Error
    Oct 2004
    that is a backsided complaint, and not necessary... its NOT gonna take me 3 months to get something coded for cinergy!!
    yea.. G has one, but we cant get to it... long story
    i should have basics done for it soon
    OH, what is the exact model information on the cinergy?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Apr 2006
    Greece
    it is a cinergy 600.
    Robby BMW had coded most of the stuff for the cinergy 600. here is the original thread he is the expert
    Cinergy 600 users wanted (enhanced RDS support available)
    MySQL Error
    Oct 2004
    yes... i know, i dont fully understand all the AF, TP, TA stuff...
    so inital realease will be light
    is this Cinergy 600, a TV Card (with fm tuner)?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. RR Config Updated - Blue ZX3
    By Blue ZX3 in forum Road Runner
    Last Post: 06-09-2011, 05:17 PM
  2. Replies: 116
    Last Post: 08-07-2008, 11:23 AM
  3. RR Doesn't Resume Music after Hibernate
    By Wiredwrx in forum Road Runner
    Last Post: 03-24-2008, 05:08 AM
  4. Songs and Folders not showing up in new RR Release
    By jwlionking in forum Road Runner
    Last Post: 09-06-2007, 03:55 PM
  5. RR 2-27-05... LATE Release (Fixes)..
    By guino in forum Road Runner
    Last Post: 03-02-2005, 01:27 PM
