Results 1 to 4 of 4
Thread: Touch screen problem
    Sep 2003
    Thousand Oak, Ca
    I tried searching but no luck.
    I have an issue using my touch screen. When a song is double clicked in the playlist window I only have a 25% chance of it playing. ½ the time the song that’s currently playing will start over and the other 25% of the time the song will just be highlighted. In other programs the touch screen works fine including winamp. I tried turning off ilist but no change and playing with my monitor setting only makes it worst.
    I have a 5 year old Xenarc monitor, running the latest RR, older versions had the same problem. The skin I’m using is a modified version DFX4. I had a drive fail and did a complete rebuild from scratch and still had the same problem.
    Thanks in advance for any light you can shed on this.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    try turning gestures off in RRConfig and see if it helps. You may want to DISABLE the right-click emulation on your touchscreen as this could also be related to the issue.
    Ride Runner RR's Myspace
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    I'm missing something. Why are you double-clicking the playlist? For me, single-click plays the clicked some and a double click will pause the existing song most of the time.
    Live mp3Car Facebook Chat
    Sep 2003
    Thousand Oak, Ca
    Guino thanks for the quick response, I have both gestures and right click emulation off. I’ll also add that if I use a mouse I don’t have this issue.
    So I wonder if this is just an issue with my monitor? I have an old liliput I will give it a try and see if it has the same problem.
    Sonicxtacy02 I have “play on list click” off so it takes a double click to play a song. The reason I have it set this way is I have been using Frodo for the last 5 years and the way it works is if you single click a song it will high light it and play after the current song ends if you double click it will immediately jump to that song. I’m still using Frodo in my wife’s car so I get grief when it jumps on the first click. Also I use the cue next command to get the same function but you have to hit 2 different buttons.
    Guino, I would love to see an option for single click cues next and double click jumps to the next song. Maybe integrate RRJTFE.
    Thanks!
  1. TM-686 Touch Screen Calibration Problem
    By piggington in forum Input Devices
    Last Post: 07-12-2008, 07:55 PM
  2. any feedback info. on Dynamix 7" VGA Touch Screen TFT ???
    By xtreamvette in forum LCD/Display
    Last Post: 04-22-2007, 04:19 PM
  3. FAQ: LCD Technologies
    By dontpntpool in forum LCD/Display
    Last Post: 03-15-2007, 01:20 AM
  4. DWW700M touch screen problem
    By All Road in forum LCD/Display
    Last Post: 08-02-2005, 04:04 AM
  5. lilliput touch screen Win XP SP2 problem?
    By alphaforcex in forum Software & Software Development
    Last Post: 12-06-2004, 03:20 AM
Tags for this Thread
