Results 1 to 7 of 7
Thread: Issues with iGuidance 4.0 and using the codes GPSSPD and GPSALT
    Dec 2007
    Reading, PA
    iGuidance works fine, but today I found out that I can set the GPS port (com 3 in this case) in the RR config and then use labels for GPSSPD and GPSALT on my main screen so I can see my speed an altitude without going to my GPS screen...however when I have that com port set to 3, iGuidance stops working. It's almost as if I can only poll the GPS receiver from iGuidance or the labels on the screen, but not both.
    Is this a bug or is there a way to get both to work? I like having the speed/alt on the main menu screen but obviously the iGuidance app is much more important.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    You need to install xPort, search for it on the forum. Split your com3 (input) to 4 and 5 (output). Set iGuidance to com4 and RR to com5.
    Dec 2007
    Reading, PA
    you sir, get a beer.
    Dec 2007
    Reading, PA
    Well, xport works GREAT, however now my date keeps changing. Last night it said 2019, and then after restarting, it came back up with 8/08/2020. I tried to manually change it in windows but it appears to be written from something else.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Config, turn off GPS date/time setting
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    OR you can try to check/uncheck the date format setting -- both are in RRConfig
    Ride Runner RR's Myspace
    Dec 2007
    Reading, PA
    I really thought I had those disabled. I guess I should double check before assuming something is FUBAR.
    Thanks.
