Please suggest me to creat Video playlist on RR.
Can I creat Vedio playlist same audio playlist ? can read root folder .etc
I use Ride runner .foobar2000 player .and elite lite 1.5 skin.
Thank you very much..
Printable View
Yes, you can do it the same way you do an audio (music) playlist -- but note that the PLAYLIST shows videos that have been LOADED from the video browser -- it doesn't show videos files or folders (that's for the video browser to show).
I attached a dirty test/example of the video playlist based on the BMV2 skin.
Thank you very much Guino
With the playlist in the video player skin, what command to you use to skip to the next video? If you notice the up and down buttons do not play the next video it just moves the selection in the playlist. It only works when there is no playlist present on the skin. I have tryin to figure this out in for a while.
The Video Playlist support still needs some more work to allow add/remove commands and such. For now, the way you can mimic the up/down function without a playlist is simply: "UP||PLAY" or "DOWN||PLAY" - however, do notice that because of the playlist, it will NOT roll from the last item to the 1st or vice versa (as it does with up/down without a playlist). I will probably add commands to do the same video functions as before as well.
