Results 1 to 6 of 6
Thread: Video Playlist on RR
    Jun 2007
    Please suggest me to creat Video playlist on RR.
    Can I creat Vedio playlist same audio playlist ? can read root folder .etc
    I use Ride runner .foobar2000 player .and elite lite 1.5 skin.
    Thank you very much..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Yes, you can do it the same way you do an audio (music) playlist -- but note that the PLAYLIST shows videos that have been LOADED from the video browser -- it doesn't show videos files or folders (that's for the video browser to show).
    I attached a dirty test/example of the video playlist based on the BMV2 skin.
    Attached Files Attached Files
    Ride Runner RR's Myspace
    Jun 2007
    Thank you very much Guino
    Newbie jakal's Avatar
    Sep 2009
    Southern California
    With the playlist in the video player skin, what command to you use to skip to the next video? If you notice the up and down buttons do not play the next video it just moves the selection in the playlist. It only works when there is no playlist present on the skin. I have tryin to figure this out in for a while.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The Video Playlist support still needs some more work to allow add/remove commands and such. For now, the way you can mimic the up/down function without a playlist is simply: "UP||PLAY" or "DOWN||PLAY" - however, do notice that because of the playlist, it will NOT roll from the last item to the 1st or vice versa (as it does with up/down without a playlist). I will probably add commands to do the same video functions as before as well.
    Sep 2009
    Southern California
    Quote Originally Posted by guino View Post
    OMG I am so dumb... Thanx a lot guino can't believe I didn't of that. I was testing different commands to figure it out.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Replies: 32
    Last Post: 07-25-2008, 08:36 AM
  3. Video problem (maybe) RR 9-5-06
    By vinzer in forum Road Runner
    Last Post: 09-09-2006, 02:29 AM
