yes you can, just point the indicator for one of desired images, use an external batch or script to continuously swap the name between the first image and the second image... it will looks like what you want.
When the indicator is "OFF," I want no indicator image to be displayed.
When the indicator is "ON," I want it blink two alternating images when using "INDICATORCODE:B" in the skin code.
Can I accomplish this using an extension plugin?
Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
Engineering: Where the rubber meets the road!
RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
Yes, instead of returning "True" in the ext pi, just return the path to one of the two images and then just use a bool var to toggle between the two paths when that ind func is called from RR. You'd also need to know when the ind would be off so that you coud return "False"
Quick sample I through together for ya.
Code:Dim IndToggle as Boolean Dim IndOn As Boolean Public Function ReturnIndicatorEx(IND As String) As String 'Default (No Action) 'ONLY return something else IF AND ONLY IF you process that code ReturnIndicatorEx = "" Select Case LCase(IND) Case "myindicator" If IndOn Then If IndToggle Then ReturnIndicatorEx = <PATH TO FIRST IMG> Else ReturnIndicatorEx = <PATH TO SECOND IMG> End If IndToggle = Not IndToggle Else ReturnIndicatorEx = "False" ' If you always want the first img to show when it turns back on then use the line below 'IndToggle = True End If End Select End Function
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Suh-weet.
I was thinking of using images, but couldn't figure out how to toggle b/w the two.
TY!
EDIT: Worked like a charm...
