Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: For Guino and RideRunner developers
  1. #11
    MySQL Error
    Oct 2004
    yes... i was gonna say that
    activesourceid, can be switched, and you can do you mutes/attns specific to your system/setup
    thanks for pointing it out MadBoy!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #12
    Nov 2004
    St Louis
    Here's a little hint to get you started (my laptop muting commands for when the tablet switches from AC to its internal battery or vice versa - a sign that the engine was just shut off or started):
    Code:
    /, ************************MUTE/PAUSE/SILENCE ON BATTERY
    "BATTERY0","BYSTR;$ONBATTERY$;External+Battery<PAUSE><<Battery+External<RESUME>"
    "BATTERY1","BYSTR;$ONBATTERY$;External+Battery<RADIOMUTE;ON><<Battery+External<RADIOMUTE;OF>"
    "BATTERY2","BYSTR;$ONBATTERY$;External+Battery<XMMUTE><<Battery+External<XMMUTE>"
    "BATTERY3","BYSTR;$ONBATTERY$;External+Battery<SRMUTE><<Battery+External<SRMUTE>"
    "BATTERY4","BYSTR;$ONBATTERY$;External+Battery<PLAY><<Battery+External<PLAY>"
    "BATTERY5","BYSTR;$ONBATTERY$;External+Battery<PLAY><<Battery+External<PLAY>"
    "BATTERY6","BYSTR;$ONBATTERY$;External+Battery<MUTE><<Battery+External<MUTE>"
    "BATTERY7","BYSTR;$ONBATTERY$;External+Battery<YT_PLAY><<Battery+External<YT_PLAY>"
    And each one of the above is tied to the audiosource variable so only one need be executed :
    Code:
    "TIMER","SETVAR;PSTATE1;$PSTATE$||SETVARBYCODE;pstate;powermon_powersrc||SETVAR;ONBATTERY;$PSTATE1$+$PSTATE$||BYVAR;CURRENTSOURCE;CHECKNETRADIO<<BATTERY1<<BATTERY2<<BATTERY3<<BATTERY4<<BATTERY5<<BATTERY6<<YTSWAP"
  3. #13
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    you could make entries in exectbl.ini for navmute to do different things depending on what screen you are in.
    the example below is what i put into my exectbl.ini for my powermate.
    Code:
    /, Powermate Commands
    /, Menu
    "LEFT1","CTRLLEFT",menu.skin
    "RIGHT1","CTRLRIGHT",menu.skin
    "LEFTDOWN1","RRPREV",menu.skin
    "RIGHTDOWN1","RRNEXT",menu.skin
    "SINGLECLICK1","CTRLEXEC",menu.skin
    "DOUBLECLICK1","CTRLEXEC",menu.skin
    "LONGHOLD1","EXIT",menu.skin
    /, Audio Player
    "LEFT1","UP",audio_player.skin
    "RIGHT1","DOWN",audio_player.skin
    "RIGHTDOWN1","RRNEXT",audio_player.skin
    "LEFTDOWN1","RRPREV",audio_player.skin
    "SINGLECLICK1","SETNEXT",audio_player.skin
    "DOUBLECLICK1","PLAY",audio_player.skin
    "LONGHOLD1","EXIT",audio_player.skin
    /, Audio List
    "LEFT1","SELDL||UP",audio_browser.skin
    "RIGHT1","SELDL||DOWN",audio_browser.skin
    "LEFTDOWN1","SELDL||PGUP",audio_browser.skin
    "RIGHTDOWN1","SELDL||PGDOWN",audio_browser.skin
    "SINGLECLICK1","ADD1",audio_browser.skin
    "DOUBLECLICK1","!SELECT+",audio_browser.skin
    "LONGHOLD1","EXIT",audio_browser.skin
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  4. #14
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    Quote Originally Posted by kuo View Post
    Code:
    /, Menu
    /, Audio Player
    /, Audio List
    So you could get leftdown to launch OBDII embedded app and rightdown to launch GPS app from menu.skin, and leftdown to launch OBDII embedded app and rightdown to launch audio_player.skin from external_gps.skin with only the powermate software and not girder. Any chance of some example code of how I might do this.........please, and I'll work the rest out from that .
    Cheers,
    Dave
    Vauxhall Astra SXi Car PC installed.
  5. #15
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Quote Originally Posted by GizmoQ View Post
    Code:
    Code:
    Hey Gismo it would be cool if you could share where you put this in RR and the Skin, and if there is any other code or .exe needed, or if you could develop a plug in.
    I have been using ShutControl, but it does not work sometimes and no longer supported, and I come back to my car and it is in unwakeable Standby cause the battery has died.
    I am also trying another app here on MP3Car, but it is missing this feature of pause on battery.
    I like to set my shutdown time for 10 minutes, so if I run into the house or a store, my PC has not completely shut down, but I dont want 10 minutes of music to have gone by.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  6. #16
    Mar 2005
    Norfolk UK
    Quote Originally Posted by Davefocus View Post
    Cheers,
    Dave
    As per my previous post......just a small bit of code to get me going, please . And confirmation that it should theoretically work too would be great .
    I'll have a go at some code later anyways but its not my forte.
    Thanks guys
  1. Been absent for a year or so, what is Riderunner?
    By obrienj in forum Road Runner
    Last Post: 07-30-2009, 05:01 PM
  2. Can't get RideRunner to use old Brushed Metal skin
    By Arathranar in forum Road Runner
    Last Post: 07-14-2009, 10:22 PM
  3. Riderunner issue with XM
    By chgrec in forum Road Runner
    Last Post: 04-22-2009, 07:26 PM
  4. RideRunner / Winamp issues
    By TxAxZxZ in forum RR Bug Tracker
    Last Post: 03-28-2009, 04:48 PM
  5. RideRunner not playing nicely with RRMediaDb
    By MGD in forum RR Bug Tracker
    Last Post: 02-18-2009, 01:55 PM
