Results 1 to 2 of 2
Thread: Winamp line in problems
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    Here's the setup:
    WinAmp v5.56 but I've tried a lot of them even the v2.3
    Vista 32 bit
    Latest RR
    Creative External USB Soundcard
    Problem is that when I just install RR and Winamp, I can hear everything fine but the EQ and preamp volume doesn't work in Winamp. And this is when I set them from WinAmp or RR.
    Now if I install the line in plugin then the EQ works. But then I get a horrible echo like everything is being played twice with a one second interval between them.
    I have the plugin line checked in RR config and I have everything setup like I have it setup on my other Car PC but this one isn't working right.
    Any ideas?
    MySQL Error
    Oct 2004
    remember when using the linein plug in, you need to have your playback side of the mixer line-in muted!!!!
    and rr.ini no linein is used... ie xmlinein=0
    when using line in plugin
    typically there is 2 sides to a pc audio system, the playback and the record
    seems alot of people get confused
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  1. Replies: 11
    Last Post: 09-06-2009, 09:20 AM
  2. RideRunner / Winamp issues
    By TxAxZxZ in forum RR Bug Tracker
    Last Post: 03-28-2009, 04:48 PM
  3. Good read on ground loops
    By coffeejolts in forum Car Audio
    Last Post: 04-28-2008, 02:30 PM
  4. onboard sound, no line in
    By TeamRSX in forum Car Audio
    Last Post: 04-08-2008, 10:57 AM
  5. problems
    By forevertheuni in forum PyCar
    Last Post: 04-26-2006, 01:00 AM
