SAL, this is a 9/1 thread, but no changes as far as i know in horm
other than one file... look at history
whats ur resumemusic rr.ini setting?
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
looks good... like i said nothing changed...so its something on your end...
i lost my hd while back with my horm vm machine... so its hard to test
maybe its ur SKIN/exectbl, something is selecting the 1st song in PL
try carwings
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
also... debug.txt would could u if anything is going on
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
Just did a test and here's the debug from the HORM resume to the point I press "PLAY" to unpause RR.
I haven't changed anything on my system.
The files are copying properly, just that it keeps resuming on the first item of the PL with the player paused. It's not even seeking to the right time.
*shrugs*
well u know that resume.ini, u posted, has plposition as 1
so that is 1st item in playlist
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
did u do simple tests, run rr, play some mp3, exit rr, run rr, should resume in that mp3
whe u shutdown, did u look at the resume.ini file saved on the horm drive?
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
I did extensive tests last night and this am checking resume.ini on the hormdrive after every shutdown and it has the right info.
Without changing anything on my carPC (same skin, same rr.ini settings, etc.), I re-installed RR v7/1/2009 and HORM resume is working properly. Ran a dozen more resume/shutdown tests and they all worked as they should.
I re-installed v8/1/2009 and the problem surfaces again.
After every install, I deleted resume.ini.
you're not helping me...
ok, so resume.ini is correct after the shutdown
it shows the correct playlist position?
i just did a history check on horm core, only changes are 9/4/2009 & 9/11/2009
so... 7/1 code is identical to 8/1
but what did change is resume.ini... in 8/1 and newer its a standard format
but it does resume correctly when i do all the basic tests... which i asked you to do...and dont know if u did....
i could make u a special build that logs the resume info...
but my inital thoughts is its working as programmed
you dont have a PL on your menu.skin do you?
mitch
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
Thanx in advance guys....I'm installing now.
