Page 7 of 10 FirstFirst 12345678910 LastLast
Results 61 to 70 of 97
Thread: RR 09-22-2009 Release
  1. #61
    MySQL Error
    Oct 2004
    Quote Originally Posted by Dartman_71 View Post
    Forget Hawaii, Silabs usbradio.dll is broken. I had to replace it with earlier fixed version otherwise I get only hissing.
    not broken here
    assuming you're using the internal audio (not winamp line in pluging)
    the dll looks up where ur device is on the mixer by the words "FM Radio"
    so u need to have your audio line in called that so it can pick the right one
    and not have more then 1, or it might pick wrong...
    same as the last version (not including the dshow version) but that did it close to that
    make sure u do have the newest .dll, i hope u didnt try to use the one in this post before i nixed it
    USBRadio.dll dated 9/14/2009 5:02pm
    SilabsRR.dll dated 9/15/2009 12:40pm
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #62
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Okay, my issue for this month is for album art on the main menu screen. I am using DFX 4 with a custom menu screen, rather than a clock or other. All I did was relace the clock with J,xxx,xxx,xxx,xxx for album art.
    WIth the august release I had no problem. With the 9/22 release the album art will come up with the first song, but when it changes to the next song the album art disappears. I uninstalled rr 9/22 and reinstalled, then reinstalled 9/22. I then uninstalled 9/22 and installed 8/1 rr and the issue is gone. I will post code etc soon.
    I have included my rr.ini, the menu skin files and my exectbl.ini. Let me know what else I need to include to help trougleshoot.
    Attached Files Attached Files
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  3. #63
    MySQL Error
    Oct 2004
    ok, albumart my fault!!!
    all fixed
    lets see about some other issues before we post anything...
    if you really need it now, pm me
    thanks drewbp
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #64
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Quote Originally Posted by mitchjs View Post
    not broken here
    I use internal audio, not Winamp line in. Problem is that I don't have FM Radio in Windows (XP) mixer or RR config??? Now Silabs plugin pick up my microphone I have newest .dll but if I replace it with earlier fixed versio it works fine. In device manager Silabs is USB composite device.
  5. #65
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Nomader View Post
    i noticed that if the PNG or GIF has BLACK in it, then the sel.bmp will cover those black pixels..
    Also Sel.bmp goes under the transparant part of the PNG (the transparant part is always displayed black..not transparant)
    EDIT. ok just figured out that black color transparancy is by design
    sorry..
    Yes, BLACK is the transparency color for folder/media icons on Standard lists, so to be consistent, it's also the transparency color on icons of iLists.
    Ride Runner RR's Myspace
  6. #66
    MySQL Error
    Oct 2004
    rrconfig doesnt look at CAPTURE(recording) devices...
    microphone?
    look at the recording side of your mixer devices
    devices, u should see FM Radio
    on XP i do!
    mixer-options-recording, mixer device FM RADIO...
    and i just tested the DLL, works perfectly
    listening to radio now
    also when u say, not working.. are u just talking about audio?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #67
    Feb 2009
    Finland
    microphone?
    on XP i do!
    Edit edit edit:
    I find FM radio from mixer after searching little harder
    Ok, I get audio now if I select FM Radio as default recording device, but it's bull! microphone has to be default rec device because I need it with phone.
  8. #68
    MySQL Error
    Oct 2004
    Yes I'm talking audio. There's no FM Radio in mixer, no playing or recording side. I even unmute everything and turn every vol slider to max but no audio. If i'm in radio and I tap microphone taping comes from speakers but if I'm audio or video no taping sound from speakers. So plugin has select microphone as radio device.
    im still not convinced your looking in the right spot in the mixer
    its accessed via OPTIONS MENU, PROPERTIES item
    then select radiobox RECORDING
    and use COMBOBOX, to list your devices...
    and if u dont have FM radio, what do u have... cause thats how we need to capture
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #69
    Feb 2009
    Finland
    I just update post above.
  10. #70
    MySQL Error
    Oct 2004
    Silabs internal audio is fixed ... USBRadio.dll is attached to 1st post
    sorry guys...
    when i was cleaning it up, and i really cleaned it up...
    i forgot to initialize a variable
    fixed and tested...
    thanks to Dartman_71!!!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Why do people think RR is hard to setup?
    By 2k1Toaster in forum Software & Software Development
    Last Post: 05-18-2008, 12:38 AM
  2. RELEASE!!! Skinable webbrowser
    By leckan in forum Other Cool Stuff
    Last Post: 01-18-2006, 03:31 AM
  3. Flash RR Skin Beta Release
    By CdRsKuLL in forum RR Skins
    Last Post: 01-15-2006, 07:48 PM
  4. RR 05-28-05.. Early Release..
    By guino in forum Road Runner
    Last Post: 06-04-2005, 08:36 PM
  5. RR 2-27-05... LATE Release (Fixes)..
    Last Post: 03-02-2005, 12:27 PM
