Page 1 of 10 12345678910 LastLast
Results 1 to 10 of 97
Thread: RR 09-22-2009 Release
    MySQL Error
    Oct 2004
    Arrow RR 09-22-2009 Release
    We have reviewed the release and fixed a few issues reported. Available now for all.
    Another month, and another RideRunner...
    Continous Improvement!
    *** Available now from here ****
    Updates soon:
    ** 9/23/2009 - Albumart art bug is fixed... (sorry) **
    ** 9/24/2009 - Silabs internal audio (USBRadio.dll) is fixed... (double sorry) file is attached to post **
    ** 9/24/2009 - Standard list, black bar on 1st item in DL, when DL has music files is fixed... **
    ** 9/28/2009 - fixed issue with caching of tags **
    ** 9/29/2009 - fixed Playlist issues on older winamp (non unicode) versions **
    WARNING: If you use the LOADLIST command for VIDEO playlists AND you use filenames with complex characters (i.e. Chinese, Japanese, Hebrew, Russian, etc), then you may have to re-do your saved playlists OR wait for the next release.
    Some highlights:
    we got blink rates for indicators now
    Improved unicode support!!!
    Improved performance of some features.
    A lot of work went into this months release:
    Thanks to Spidermunz for all his help in helping me understand some of the advanced features of RDS
    of which arnt used in USA so its was/is very hard for me to test them, yet alone
    understand them. He has shared with me his EON code for the SiLabs Driver (usbradio.dll) I have added in
    some of the featues into the silabs radio module and made some other changes to it...
    this is for sure a work in progress...
    currently Spidermunz and I continue (even as i write this) to work on it
    thanks Guino for his CONTINUED improvement of RideRunner
    thanks to Bluezx3, for his commitment to this, and for RRConfig
    edit: thanks to Mitch for his great contributions (software+hardware) to the community
    Notes:
    silabs radio, audio disables itself (audio), when you use "uselineinplugin=true"
    this allows the winamp lineinplugin to work nicely,
    audio is able to be processed by winamp (dsp,eq....)
    thanks
    Mitch
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = bug fix
    ^ = Note
    9/22/09
    # Fixed CLICKIND for indicators inside buttons
    # Fixed Issue with ONSONGSTART (executing for every screen)
    # Fixed Issue with Daylight Savings on Gamma/Skin GPS based changes
    + Added "Daylight Savings" awareness to the gps gamma feature
    9/21/09
    + added additional field for label definitions
    	/,  x   y   w   h   r   g   b   pt font             Code tooltip format
    	LXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XX,"Arial Narrow:B",CODE,"Time","fmt"
    	examples:
    		L,474,75,250,27,212,208,200,16,"Arial:B","FREEMEM||=kb","LEFT","kb"                              (shows mem in kb, with static text of kb)
    		L,474,75,250,27,212,208,200,16,"Arial:B","FREEMEM||=kb   ||MBM1","LEFT","kb||||cf2"        			 (shows mem in kb, and temp in f, "f" is automaticly appended)
    		L,474,75,250,27,212,208,200,16,"Arial:B","FREEMEM||=kb   ||ALLMEM||=kb","LEFT","kb"              (shows both in kb)
    		L,474,75,250,27,212,208,200,16,"Arial:B","FREEMEM||=   ||ALLMEM","LEFT",""                       (shows both in mb with spaces a static text)
    9/18/09
    # fixed resumemusic=1, now resumes to radios since the wording "music" is a loose term (also activesource is correct when resumemusic > 0)
    # fixed issues with custom labels
    9/11/09
    - Removed Disable Internationalization Setting (obsoleted)
    + Improved OSKTOCMD and NUMOSKTOCMD to accept ++ in place of ||
    + Custom indicator blink rates
    * More skin cleaning/organizing done
    9/10/09
    - "LOCALE" - rr.ini setting obsoleted
    * MPC Video Player Updated to work with unicode filenames (All other players are already unicode compliant)
    + "RDSEON" - Indicator the RDS EON is present (SiLabs)
    + "RDSAFLIST" - Label RDS AF List (pipe seperated "|") (SiLabs)
    + "RDSEONCOUNT" - Label RDS EON Map Size (SiLabs) (ment for use in plugins)
    + "RDSEON1" - Label RDS EON Map x - (Pipe seperated "|") (SiLabs) ("PI|PS|PTY|TA|AF1|AF2...AFn")  (ment for use in plugins)
    + "RDSEON2" - (see RDSEON1)
    + "RDSEON3" - (see RDSEON1)
    + "RDSEON4" - (see RDSEON1)
    + "RDSEON5" - (see RDSEON1)
    9/09/09
    + "uselineinplugin=true/false" RR.ini setting automaticly disables internal audio when TRUE (SiLabs)
    9/08/09
    + "RDS_TA" / "TA" - Skincommand to enable disable traffic alert events "ONRDSTASTART" & "ONRDSTAEND" (SiLabs)
    + "RDS_TA" / "TA" - Indicator, shows state of traffic alert events (SiLabs)
    9/04/09
    + Improved Tag Reading to work better with Unicode File Names
    + Improved Labels to work better with Unicode Text
    + Improved Standard Lists performance
    + Improved Album Art Browse performance
    + Improved iLists and Standard Lists to work with PNG, JPG and other GDI+ file types
    + Improved Audio Players to work with Unicode
    # Fixed LazyTag option bug on Folder Lists
    # Fixed issue Closing MPC on some machines
    9/01/09
    # label click "exec;xxxx" fixed ending " is now allowed
    8/28/09
    + Custom Blinking rate to indicators
    Attached Files Attached Files
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Low Bitrate JohnnySierra's Avatar
    Mar 2009
    Italy
    Thanks for your great job.
    We're waiting the release.
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    Again sure a good new release
    Constant Bitrate insaneramman's Avatar
    Mar 2008
    South Carolina
    Cool Do you sleep?
    You guys are amazing. I just finally got 08-01-09 in and now I'll be even further behind. Thanks for all the hard work ALL of you guys put in. RIDE RUNNER is the main reason I put a computer in my truck and ALL of you continue to prove to me I made a SMART decision. I hope all involved will continue to have the time and patience to update and improve RR.
    For those who fought FREEDOM has a flavor the PROTECTED will never know. Support our troops.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Thanks!
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    a toast to you guys
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Nov 2007
    this is nice..
    thanks guys, downloading the new version.
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    So, what I need to do now to get audio from radio (Silabs). It was working fine until now! I also try enable line in plugin but that not work either.
    I get quiet hissing when I go radio and it stops when I go music.
    Should I change text in line in plugin box or should default "line://title=Radio,srate=44100,bps=16,nch=2" work? I'm using Winamp 5.552
    Edit:
    I get it to work after few reboots, but there still something wrong:
    If I listen music and restart RR both radio and music start to play at the same time???
    If I listen radio and restart RR then it start to play radio like it should.
    If I listen radio and go to video, radio stays playing behind video???
    Constant Bitrate almera's Avatar
    Aug 2004
    I'm using silabs radio and something wrong with my system also;
    Radio start to play everytime RR starts?
    Also something wrong with winamp playlist, if I switch to TV (winamp plugin) and back, getting empty playlist named "rrpl"?
    Thanks for the release..
  1. Why do people think RR is hard to setup?
    By 2k1Toaster in forum Software & Software Development
    Last Post: 05-18-2008, 01:38 AM
  2. RELEASE!!! Skinable webbrowser
    By leckan in forum Other Cool Stuff
    Last Post: 01-18-2006, 04:31 AM
  3. Flash RR Skin Beta Release
    By CdRsKuLL in forum RR Skins
    Last Post: 01-15-2006, 08:48 PM
  4. RR 05-28-05.. Early Release..
    By guino in forum Road Runner
    Last Post: 06-04-2005, 09:36 PM
  5. RR 2-27-05... LATE Release (Fixes)..
    Last Post: 03-02-2005, 01:27 PM
