Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: RR not displaying ID3 from playlist load
  1. #11
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    did you try using the LOALIST command?
    Ride Runner RR's Myspace
  2. #12
    Constant Bitrate Stealth915's Avatar
    Bay Area, CA
    The LOADLIST command works but doesn't it requires an absolute path to the m3u file?
    Code:
    "LOADLIST;D:\Music\~Playlists\test.m3u;my playlist"
    Is there a way to get it to load the currently selected playlist file in the load_playlist skin?
    2004 Mazda3 Carputer Worklog - Update 5/17/11: Carputer 2.0 Hardware Selection
  3. #13
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, "SELECT"
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #14
    Bay Area, CA
    Hmm, "SELECT" is the command being used by the skins, and using it to load a playlist doesn't load the ID3 tags.
    Does RR handle loading a playlist with SELECT differently from using LOADLIST? Is anyone else having this problem?
  5. #15
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you highlight the M3U file and hit "SELECT" then it should be exactly the same as LOADLIST. If you go INTO the playlist (using "BROWSE") then hit "SELECT" it will NOT be the same thing.
  6. #16
    Bay Area, CA
    I FIGURED IT OUT!
    All of my M3U playlists use relative paths:
    Code:
    #EXTM3U
    #EXTINF:236,Avant - When It Hurts
    ..\new\04-avant-when_it_hurts.mp3
    #EXTINF:319,Eminem - My Mom
    ..\new\03 My Mom.mp3
    #EXTINF:243,Flo Rida (feat. Ne-Yo) - Be On You
    ..\new\07  Flo Rida - Be On You [Feat. Ne-Yo].mp3
    If I change it to use the absolute path of the files, everything works fine:
    Code:
    #EXTM3U
    E:\new\04-avant-when_it_hurts.mp3
    E:\new\03 My Mom.mp3
    E:\new\07  Flo Rida - Be On You [Feat. Ne-Yo].mp3
    Still, this seems to be a strange problem. In summary:
    Using relative paths in an m3u playlist will cause the ID3 tags to not display properly. When this happens I have found 2 ways to get it to display the tags correctly:
    1) Exit RR and reload it
    2) Go into HD Radio and change the channel a few times (not quite sure why this works)
    Anyways, I'm not sure if this would be considered a bug in RR, but would it be easy to fix? In the meantime, I'll convert all my playlists to use absolute paths.
  7. #17
    MySQL Error
    Oct 2004
    rel path seems bad to me, the question would be relative to WHAT
    when rr is running, the current drive is RR root
    rr is prob not gonna know where to open those files for tag...
    but in winamp... i dont know whats the current drive
    also... if you are using winamp...
    you know, u could and prob should let winamp process tags
    try that, ive posted it a few times how to set winamp up to do the tags
    its an option in winamp->preferences->titles
    on the new winamp, i chose the last option, read metadata in the backgound...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  8. #18
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Relative paths are not really supported in RR (because like mitch said -- relative to WHAT path?), however, when you close/exit RR and re-open it , it will tell winamp to save the playlist (for resuming later) and it will likely save it without relative paths, that's why it works the next time around.. this happens in a similar fashion when you use TV/HD/Video etc where RR asks the player to save the playlist so it can resume later.
  1. ID3 versions, what does RR use?
    By Dougw133 in forum Road Runner
    Last Post: 03-16-2009, 01:23 PM
  2. Displaying IBUS information on RR
    By wookie_g in forum Road Runner
    Last Post: 07-14-2007, 09:59 PM
  3. RR fails to load / vis display glitch
    By RhinoT16S in forum RR Bug Tracker
    Last Post: 02-23-2005, 09:14 PM
  4. Playlist Load bugs
    By teedty1 in forum MediaCar
    Last Post: 03-08-2004, 12:42 AM
  5. Slow playlist load at winamp startup
    By xa0s in forum Software & Software Development
    Last Post: 08-18-2000, 11:16 AM
