Results 1 to 10 of 18
Thread: RR not displaying ID3 from playlist load
    Constant Bitrate Stealth915's Avatar
    Bay Area, CA
    I seem to be having trouble getting RR to display ID3 tags (and album art) in the audioplayer screen when I load a M3U playlist. It only displays what is to the right of the rightmost "dash" of the filename in the TAGARTIST field.
    For example, my M3U file looks like this:
    Code:
    #EXTM3U
    #EXTINF:236,Avant - When It Hurts
    ..\new\04-avant-when_it_hurts.mp3
    #EXTINF:319,Eminem - My Mom
    ..\new\03 My Mom.mp3
    #EXTINF:243,Flo Rida (feat. Ne-Yo) - Be On You
    ..\new\07  Flo Rida - Be On You [Feat. Ne-Yo].mp3
    When I load it using Load List button (SELECT command... i think), I get this:
    but if I exit RR and launch it again, the ID3 displays correctly:
    This only happens for loading music via playlists. When I go through the Library using the "Add Folder" command, everything's fine.
    I am using the latest RR (08/2009) with Winamp 5.13. I have tried both eLite and DigitalFX and the problem exists with both skins, so I don't think it's a skin problem. Any thoughts on why this is happening?
    2004 Mazda3 Carputer Worklog - Update 5/17/11: Carputer 2.0 Hardware Selection
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Check your settings in RRConfig under Music/Page 1. You can set what you want to display like: %artist% - %title%.
    Try making the settings on Music/page 1 in the config to:
    Prefer ID3V2 tags
    Show ID3 Playlists
    Show ID3 Browse
    and set both text boxes to:
    %artist% - %title%
    If they are set that way already, then you may want to investigate the actual tags in the MP3's further.
    My Fiero Build Thread
    Bay Area, CA
    I have those settings checked in RRConfig, and the ID3 tags display correctly in the Playlist and Browser screens, it's just in the actual player that the tags don't show up correctly.
    Here's the music portion ofmy rr.ini file:
    Code:
    [Music]
    musicpath=E:\Sorted\
    playlistpath=E:\~Playlists\
    useid3=2
    showid3playlist=true
    showid3browse=true
    lazytag=false
    singleclickaudio=false
    noformat=true
    listnumbers=true
    listfollowssong=true
    id3listformat=%artist% - %title%
    id3browseformat=%artist% - %title%
    titlesafter=-
    albumart=*.txt
    fadeimages=true
    audiofiles=.m3u,.mp3
    visuname=MilkDrop
    scrollmode=1
    circularlist=true
    groupnumbers=false
    resumemusic=2
    audiorepeat=last
    audioshuffle=last
    transparentvisu=last
    opacityvisu=40
    MySQL Error
    Oct 2004
    see
    titlesafter=-
    that means it will get the title after the -
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Bay Area, CA
    Hmmm, OK, I changed "titlesafter" so that it's blank, but that still doesn't really solve my problem... now it's showing the entire filename in the Artist field of the audioplayer. I'm trying to figure out why the ID3 tags aren't being shown when I load from a M3U playlist. The Playlist and Library screens show the ID3 tags correctly, just the Audioplayer screen that doesn't.
    RR only uses "titlesafter=" if it doesn't have ID3 information, right? All my music files are correctly tagged with ID3v2.
    If I exit out of RR, or if I go into HD Radio and come back to the Audioplayer screen, the ID3 tags show correctly. Any ideas? =)
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    open audio_player.skin in elite and add this line:
    S00,800,000,001,600,230,000,000,000,000,000,000,00 0,000,190,025,025,255,255,255,FALSE,015,"Arial"
    and see if that helps.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Ah.. the imformis hidden playlist...if in fact that does fix it. I've looked at the code and still don't understand Y adding a hidden PL to screens seems to fix these types of issues...
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    the display of the playlist is what "triggers" RR to read the tags.. if a file isn't displayed there's no need to waste time reading the tag. The hidden playlist makes RR think the tag needs to be displayed and because of that RR will then read the tag. However the CURRENT track/song will always have the tag loaded even without any playlists.
    Ride Runner RR's Myspace
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Maybe create a internal flag that if when the screen is loaded and contains any of the tagxxx labels, it would then update as if you added that hidden pl, which I have always thought was a silly workaround and inefficient use of a control! And to most, is something that is always missed and then creates either threads like this one to re answer a x10 already asked Q OR waste the users time to have to search for how to fix it. That is my thoughts & opinion on it....
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Bay Area, CA
    thanks for the replies! Unfortunately, adding that line to the audio_player.skin doesn't fix the problem.
    I'm sorry if this has been asked elsewhere - I've tried searching for this problem before posting ("m3u" doesn't give many results but "playlist" gives far too many).
    Any other ideas? I'm willing to test out any and all suggestions. Thanks, and much appreciated!
  1. ID3 versions, what does RR use?
    By Dougw133 in forum Road Runner
    Last Post: 03-16-2009, 01:23 PM
  2. Displaying IBUS information on RR
    By wookie_g in forum Road Runner
    Last Post: 07-14-2007, 09:59 PM
  3. RR fails to load / vis display glitch
    By RhinoT16S in forum RR Bug Tracker
    Last Post: 02-23-2005, 09:14 PM
  4. Playlist Load bugs
    By teedty1 in forum MediaCar
    Last Post: 03-08-2004, 12:42 AM
  5. Slow playlist load at winamp startup
    By xa0s in forum Software & Software Development
    Last Post: 08-18-2000, 11:16 AM
