Results 1 to 10 of 14
Thread: what antenna/setup to use w/ ADS instant FM
    Variable Bitrate afterdigital's Avatar
    Aug 2006
    New Ro, NY
    I have the ADS FM and cannot get constant good reception. I tried following someone's recommendation of soldering a cable which allow me to connect to the car radio. This also goes in and out. Is there anyone using this unit successfully in their car?
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
    MySQL Error
    Oct 2004
    for sure u need that mod, with the wire, inside it doesnt do very good
    and im sure in a car...
    even with the mod.. antenna issues maybe there
    in your car, what kind of antenna you have, in glass?? its it amplifed? did u power on the the amplifer....
    course ur in USA, HD Radio would do u better, its tuner made for a automotive use... but some of the antenna issues would remain, ie amplified....
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Aug 2006
    New Ro, NY
    from my understanding, the ADS unit does not work well with the glass mount antenna of any vehicle so i disconnected the cable from the glass mount. Yesterday i was getting superb reception while in the city. As i was driving back home i began losing reception and when i was home i could not get anything. That is until i move the antenna or play around with it.
    My point is to know if there is an antenna i can get to add to the unit. I like it and it works well "when it works" - i think a good antenna will resolve this issue..
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    Finished Project
    Car Hacking
    WorkBlog
    Video
    MySQL Error
    Oct 2004
    none that i know of... all antennas are a bit of a hack on those tuners
    u did have the glass antenna powered on right? they are usually amplified
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Aug 2006
    New Ro, NY
    Quote Originally Posted by mitchjs View Post
    not sure what you mean by amplified as the glass antenna is the factory antenna provide with the factory car. I'm not sure how the factory installation is setup?
    I did, however, go to radio shack and purchased an amplified antenna (which i can return for full refund) connected it, plugged the ac adapter into an outlet and depending on where i positiioned the antenna, it would work great but that's unacceptable.
    I have a strong feeling the usb fm radio is getting feedback from the pc, wires, hubs and the likes. What i'm considering doing is getting a long usb extension cable, running it to the back of the car and plugin the fm radio by itself back there. we'll see if this works...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    Finished Project
    Car Hacking
    WorkBlog
    Video
    MySQL Error
    Oct 2004
    the pc might be killing fm too
    but 99% of all on glass antennas are amplified
    the factory radio, 1 turns on a amplifier remotely mounted in car
    or 2 contains the amp
    if your not using the factory radio, to use that antenna, you have to turn it on
    basic car audio...
    maybe ask a car audio shop
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Aug 2006
    New Ro, NY
    @mitchjs
    i kepted my DIC and factory radio intact. I disconnect the antenna from the factory radio and connect it to my USB FM unit and nothing.
    What i may try is extending the cable to the usb fm as far away from the pc/cables/hubs and running a connection to the antenna.
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    Finished Project
    Car Hacking
    WorkBlog
    Video
    MySQL Error
    Oct 2004
    are u keeping the factory radio ON??? when ur trying to use the antenna
    it also can send the power up the antenna wire (like vws do, and u need an adaptor)
    you might want to do more research on you car...
    its a high end car, not a toyota!!!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Mar 2009
    Hi, I ordered an ADS InstantFM stick and I have a glass mounted antenna on a VW T4. There is an amplifier that fits with the factory radio. Maybe this kind of adapter will work.
    http://www.carteq.fr/categories/gran...-pour-voiture/
    Sorry but it's french
    Aug 2006
    New Ro, NY
    thanks, i will look into this on my car forum...
    in the meantime, i'm going to also try distancing, using another antenna i'm borrowing from a friend, and better soldering connection to the cable.
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    Finished Project
    Car Hacking
    WorkBlog
    Video
  1. help with ADS Instant FM
    By wired48 in forum General Hardware Discussion
    Last Post: 06-06-2009, 10:58 AM
  2. ads instant fm in sd
    By Curtis513 in forum StreetDeck
    Last Post: 01-29-2009, 11:06 PM
  3. Help with ADS FM radio in SD please!
    By gazorp in forum StreetDeck
    Last Post: 05-06-2008, 10:30 AM
  4. RR integration with ADS USB FM stick (Silab chip)
    By GuMiSZu in forum Road Runner
    Last Post: 04-18-2007, 07:29 AM
  5. ADS Tech Instant Music - DAC? USB SC?
    By drPheta in forum Car Audio
    Last Post: 11-18-2006, 08:42 PM
