try sending to explorer.exe, i am not sure wether that will work but i think it should.
why not trying usong the button in rr to open the navida screen rather than send crtl q
I've got my pc configured so that a "Ctrl-Q" command launches my nvidia nview screen that lets me change my desktop mode from dual view to extended.
When I'm using RR and I push the Ctrl-Q on my keyboard, the nview screen appears and I am able to do what I want. I've created a button on a RR screen and given it the following command:
"SENDKEY;^{q}" and when I use it nothing happens. I've read about the "ACTIVATE" command, but I'm not sure what I should be activating. The Ctrl-Q command is sent to windows....how to I use the sendkey command to send to windows and not a specific app?
Any help would be greatly appreciated.
Sendkeys does NOT work for everything. In any case..
How did you map CTRL+Q ? If you did it by a windows shortcut, all you have to do is copy the command line used to open the screen and use the RUN command on a button to execute the same thing.
For the nview application itself, you may want to check this:
http://www.dtvforum.info/index.php?showtopic=39689
From the above, you should be able to at least make 2 buttons to switch between a profile and another directly (using the RUN command on each with the desired parameters).
Ride Runner RR's Myspace
The ctrl+q was mapped in the nview software itself. I did try activating the "explorer.exe" before posting this, but was unsuccessful. I'll read through the above post and see what I can figure out.
Thanx guino.
Try this one "SENDKEY;(^+q)"
Thanx...tried it but it didn't work.
I took another approach with it. When pressing Ctrl-Q, the nvidia driver was actually launching an exe named "nvdspsch.exe". When I call this executable directly from the command line is works as desired. So instead of using sendkeys with the ctrl-q, I'm using a custom command setup in the ExecTBL file that executes RR's RUN command with the appropriate path/filename.
Thanx everyone for the help/suggestions.
