Do you have any timers running on these screens. I created a battery check based on a label change that requires a timer:
Basically with a 15 second timer the above code saves the text of the label "powermon_powersrc" and compares it to what was saved last time. When it changes, it acts (in this case when change from external to battery it pauses RR, i.e., when I take the key out of the ignition and when it changes from battery to external it resumes). This code could easily be changed to run a loadimg command like I have for InetAudioCode:"SETVAR;PSTATE1;$PSTATE$||SETVARBYCODE;pstate;powermon_powersrc||SETVAR;ONBATTERY;$PSTATE1$+$PSTATE$||BYSTR;$ONBATTERY$;External+Battery<PAUSE><<Battery+External<RESUME><<<RELOADLIST"
Did Blue suggest the BYLBL command in RRExtended? I know my code above could be streamlined using it (I wrote it when RRextended was first released and haven't kept up with the updates). I'm not familiar with the INCLUDE.txt, but you say they're indicators, can't the BYIND command be used to change the indicator graphics?
LinkBack URL
About LinkBacks
