Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Road Runner slide show
  1. #11
    Sep 2012
    Germany - Munich
    just a tip:
    open the carwings skinfiles and look what you miss in yours.
    you always send snippet parts of your skin file. it's difficult to understand, when you don't show the skin file.
  2. #12
    Aug 2007
    i use this way , and working fine
    PICTUREVIEW.SKIN
    RideRunner Skin
    RRScreen picviewer
    /INC,Topbar1.txt
    IMG,24,78,508,403,"IMAGENS\Wood9.png",ALL
    IMG,708,13,40,35,"Icons\speaker icon.png",ALL
    J01,44,89,468,380
    L,144,537,101,23,255,255,255,13,"HandelGotDLig","= Slideshow","CENTER",
    L,300,26,177,31,255,255,255,20,"HandelGotDLig:B"," =Pictures","CENTER",,"ds=2,2,0,0,0"
    L,616,23,80,18,255,255,255,11,"HandelGotDLig:B","= CPU: ||CPU","LEFT",
    L55,38,89,480,380,,,,,,"EXEC;LOAD;picture.skin","" ,
    B,148,521,94,58,"BYVAR;SLIDESHOW;SETVAR;SLIDESHOW; 1<<SETVAR;SLIDESHOW;0||LOAD;PICVIEWER_FULL.skin",
    B,42,521,94,58,"LOAD;PICTURE.SKIN",
    B22,0,2,86,56,"EXIT",
    B,554,522,98,58,"UP",
    B,662,522,89,59,"DOWN",
    B22,253,522,90,58,"BROWSE",""
    B23,452,521,92,61,"BACK",""
    B,713,13,35,35,"MENU;VOLUME_MENU.SKIN",
    B,351,495,94,95,"BROWSE","SELECT"
    IL,DL,transparent.bmp,sel1.bmp,end.bmp,1,50,80
    S04,557,98,193,365,255,255,255,57,57,57,255,255,25 5,255,255,255,200,200,200,0,0,0,TRUE,15,"HandelGot DLig:B"
    END
    and PICTUREVIEW_FULL.SKIN
    RideRunner Skin
    RRScreen "PICVIEWER_FULL"
    PICVIEWER_SLIDER.png,PICVIEWER_SLIDER.png,PICVIEWE R_SLIDER.png,PICVIEWER_SLIDER.png
    TMR,4,"BYVAR;SLIDESHOW;<<NEXTPIC"
    I01,0,0,800,600,"PICTURE:A",,,
    RG,0,0,200,600,"PREVPIC"
    B,200,0,400,600,"BYVAR;SLIDESHOW;SETVAR;SLIDESHOW; 1<<SETVAR;SLIDESHOW;0||EXIT",
    RG,600,0,200,600,"NEXTPIC"
    /, Hidden List
    S,0,0,0,0,,,,,,,,,,,,,,,,,,
    END
    my problem is when i click slidershow button in skintool put SLIDESHOW;1 so tunr on slidershow , but i dont turn off , for when i open full screen again working fine , so now , when click on screen full turn off , and then if like it open again the screen full , begging again turn on
  3. #13
    Sep 2012
    Germany - Munich
    yes the button which loads the fullscreen, sets the var slideshow to 1
    check the var SLIDESHOW in skintool.
    when you turned:
    -on, there must be a 1
    -off, there must be a 0
  4. #14
    Aug 2007
    yes , i see that , that is one of my error
  5. #15
    Sep 2012
    Germany - Munich
    why not fix it?
    does it mean you want an own button to switch ON/OFF the slideshow?
    and one button only to switch to fullscreen?
  6. #16
    Aug 2007
    i fix , if you see in the mys skin , i have a button for call the slidershow (turn on) this
    and then open the big screen , and when i click in the center of the big screen ( turn off) and go back to pictureview regular this
    now working fine with that code
    my principal error is when i call to big screen , the slider turn on , but the old code for turn off dont working well , so with this now , working fine
  7. #17
    Sep 2012
    Germany - Munich
    do you mean your error was fixed already in post #12?
    then you must write: my problem was....
    otherwise i misunderstand your words.
  8. #18
    Aug 2007
    jajaj my english is bad , yes i fix the error , the skin on post #12 , is working fine now
  9. #19
  10. #20
    Aug 2007
    yes perfect
  1. Road Runner and Iguidance v4 locks my computer.
    By kickercivic1 in forum Road Runner
    Last Post: 10-13-2007, 08:49 AM
  2. New road runner will not show after loading
    By ImOj in forum Road Runner
    Last Post: 09-28-2007, 09:05 PM
  3. How to Speed up Road Runner
    By JohnWPB in forum RR FAQ
    Last Post: 09-15-2007, 02:58 PM
  4. Replies: 18
    Last Post: 08-03-2007, 09:02 PM
  5. Road Runner Shell Issue
    By B|ade in forum Road Runner
    Last Post: 05-24-2007, 06:00 AM
