Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: RR/Winamp Shuffle
  1. #11
    Constant Bitrate tom_rosenback's Avatar
    Oct 2006
    Finland
    Just made a small test in Winamp v5.51. Shuffle order changes everytime the shuffle function is toggled on. Short test, to describe Winamp shuffle.
    1. Shuffle on, and then next, next...
    2. This gives the following order of tracks 231, 262, 120, 184, 51, 299
    3. Then clicking previous button until back on track number 231
    4. Just to verify shuffle order hasnīt changed, next gives track 262
    5. Prev to track 9
    6. Shuffle off, shuffle on, next, next....
    7. This gives the following order of tracks 259, 210, 7, 186... Completly different from earlier next clicking.
    Conclusion: Winamp changes the shuffle order when enabling shuffle functiom
    -> Is it possible to make the next button in a skin to do the following:
    If shuffle is enabled, disable it and enable it again and then next track?
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This is the correct behavior programmed.
    It is possible to make a command that plays the next song regardless of the shuffle status. On screens with a playlist, this is as simple as changing the command from "NEXT" to "DOWN||PLAY" -- however keep in mind that this is not going to fast forward when you press-and-hold, so you may be better off making a separate button for that, or just click on the song in the playlist and hit play or Double-click it (or even set it to play on single click then just do 1 click on the song).
    Ride Runner RR's Myspace
  1. The dreaded Shuffle issue.....again :(
    By TURSTY in forum Mobile Impact
    Last Post: 02-06-2008, 01:06 PM
  2. Shuffle button change request...
    By WuNgUn in forum Centrafuse
    Last Post: 01-07-2008, 11:39 AM
  3. Shuffle Problem - Music and Satellite Modules - 1.1.0.0
    By Tranman in forum StreetDeck Bug Reports
    Last Post: 12-14-2007, 09:20 AM
  4. Replies: 1
    Last Post: 01-22-2007, 09:00 PM
  5. shuffle videos in RR
    By navank in forum Road Runner
    Last Post: 09-17-2006, 10:00 PM
