Results 1 to 10 of 12
Thread: RR/Winamp Shuffle
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    RR/Winamp Shuffle
    I have always added my entire collection to the playlist and let it play on shuffle. Once and a while I would get to a song/artist of an album I liked. I would just take it off shuffle and it would resume normal play mode. I would advance to the next track in the album and so on. Now, when I take it off shuffle in the middle of the playlist it seems to still be shuffled and skip around. It will advance to a different album of the same artist or just continue down alphabetically but not in order. It's like when I load the playlist of "ALL/Entire" or just using RR MEdia DB to play select "Entire" it loads the Entire Collection pre shuffled. What changed? What can I do to get it to play the entire collection in proper succession? Thanks.
    May 2006
    Calgary, Alberta
    I'm comprehension. Have we met?
    Seriously, I can't understand any of that but maybe try loading Winamp on its own and get your playlist set the way you want.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Nov 2007
    PA
    Quote Originally Posted by Maheriano View Post
    Well, sorry it didn't meet your IQ.
    Load an album songs 1-9.. Put it on shuffle. lets say you are now on track 5. Take shuffle off and when you press to advance to the next track it should be track 6. In my case, when shuffle is turned off for (ie) track 1-9, it will go from track 5 to track whatever it wants ,7,2,4...I did not always do this and I do not recall changing any settings regarding the issue. It just happens to be an on the fly playlist. I Play my entire collection on random, I want to be able to turn random off when I hit an album I like, and have stay there.
    May 2006
    Calgary, Alberta
    Things to try:
    1. Is it randomizing the playlist and playing the randomized list in order? Or is it actually jumping to the second song in the playlist while looking at it?
    2. Some skins have the same button for loop and shuffle. With Carwings Dynamic you have to hit this button twice to get shuffle turned off because it cycles through shuffle, loop, shuffle and loop, nothing. Or maybe it's random instead of loop, I forget what the other one is, I don't use it.
    3. Load the playlist in Winamp and see if it behaves the same way.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Nov 2007
    PA
    Things to try:
    Well it was loading the first several songs correctly to the playlist. I have NO odea what I might have done but it seems to be working correctly again after 3 months...Thanks for the good suggestions
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can also disable the hideplayer option and just "view" the songs in winamp's playlist to see what's going on. You may even just look at winamp (outside RR) after you loaded all your songs to see if they're in the desired order. I suggest you try this first on a basic skin like carwings/bmv2 as some skins/plugins can modify the behavior of standard functions.
    Ride Runner RR's Myspace
    May 2006
    Calgary, Alberta
    Quote Originally Posted by Dougw133 View Post
    You're frustrating the hell out of me, this post is just as vague as your original post and makes no sense. Is it fixed? Does it work now? How did you fix it? Other members may have the same issue and will find this thread on a search. It would be helpful for them to have a solution. Thanks.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    RRMedia will only shuffle the list if and only if you have the list mode set to random other wise it creates the list in the same order in which is was indexed in (by folders)
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Nov 2007
    PA
    It is "fixed"
    Here is what I believe my problem was. Aside from having shuffle on in RR, in RR Media I had "Sort By Song Number" on as well. I figured this would arrange songs in albums by Number as most of us would like. But what I think was happening was that it was loading the "All/Entire" into the playlist by "Song Number". So when i got to an Artist with multiple albums containing several songs by that artist with a track # of 8, it would skip to # 8 of each album, and then onto 9, etc.. there for seemingly "still" in shuffle. I changed "play mode" to "by name" and it is back to normal.
    May 2006
    Calgary, Alberta
    Good thinking.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. The dreaded Shuffle issue.....again :(
    By TURSTY in forum Mobile Impact
    Last Post: 02-06-2008, 02:06 PM
  2. Shuffle button change request...
    By WuNgUn in forum Centrafuse
    Last Post: 01-07-2008, 12:39 PM
  3. Shuffle Problem - Music and Satellite Modules - 1.1.0.0
    By Tranman in forum StreetDeck Bug Reports
    Last Post: 12-14-2007, 10:20 AM
  4. Replies: 1
    Last Post: 01-22-2007, 10:00 PM
  5. shuffle videos in RR
    By navank in forum Road Runner
    Last Post: 09-17-2006, 11:00 PM
