Perhaps this has been discussed before, but I didn't see it and think it would be good practice...
Would it be possible for the downloads to have the date / version number included in the file name?
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Mostly Useless Info - Free Image Host
i'm working to end the develope of silabs module
i think can be make it in 4-5 days (i must add some detail to some function)
it is a "porting" and "merging" of my old plugin and base rds/old-silabs module
when i save my user-preset (0-9) i name the preset grabbing the rds name
if all whants i can name all the station using the rds radio name (if it has), is simple
all purpose (if are ok for guino and mitchs) are welcome
[QUOTE]Above what signal strength does this search occur? and can that level be adjusted?/QUOTE]
in my old plugin i can adjust the level strength under the radio must search an alternate frequencies, user can set it inside the silabs.ini config file (r from a form inside rr (in my old plugin)
2 example:
preset rds name (i use a popup)
http://www.mp3car.com/vbulletin/rr-p...ml#post1232910
and the form loaded inside rr by my old plugin
next have less options to be saved (all audio var doesn't be used)
GizmoQ, yep... do searchpresets
that will switch to local, search for presets, and they save in radiolocal.ini
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
Think I'm the first one to download this month. Thanks for the constant updates and improvements.
CAR: 2007 G35 Sport Coupe 5AT
HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
Thanks guys transparent in ilist works great for me thanks for that fix,
Skin editor , get run-time error "53" file not found , on load of a skin ,????
Riderunner / Genesis
Wifiman_NET:Version 1.0.0
Yes, already noticed and fixed..
[Edit]
Attached file removed, had another gremlin lurking..
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
cheers Blue works
Thanks for this new release . I test it as soon as possible .
I LOVE RR ...![]()
it works ok in vista..but windows 7 has problems..unicode etc..(don't flame me)
