Page 6 of 17 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 164
Thread: RR 10-05-2009 Refresh Release (Available Now)
  1. #51
    MySQL Error
    Oct 2004
    it doesnt have to be mp3art
    it could be any plugin that touches albumart
    i have seen a plugin try to use albumart, when it shouldnt too!!!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #52
    Dec 2007
    yeah.. guino has sample songs.. So, all i have to do to use foobar is to install foobar2000 and COM SERVER and set the player to foobar(auto) in config? Is that it? Is foobar native just like winamp?
  3. #53
    Feb 2006
    [QUOTE=mitchjs;1346957]brandensin, vinchan, i think you guys are both dealing with chineese unicode....
    Enclosed are the pictures... It happens whenever I need to browse files.
  4. #54
    MySQL Error
    Oct 2004
    Quote Originally Posted by brandensin View Post
    sounds right..... i did only try foobar2000 once way, back when G 1st did the module...
    native is a loose term here, but RR directly controls it via the com interface
    ONLY use the foobar add on in the installer, i cannot say if the one in the post in the forum is up to date!!!
    the one in the installer has the unicode support
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #55
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Yes, already noticed and fixed..
    I downloaded this file and have noticed the following:
    I receive a run-time error,
    Run-time error '381'
    Invalid property array index
    or it returns a complete different screen then the one that I am currently working on at the moment.
    This happens when going form standard skin editor mode to virtual editor and back to skin editor mode.
    This was also was happening before I replaced the skin editor (10-01-09 included file) with the one I downloaded.
  6. #56
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Does it do it on the same screen, all, random. Could be something you have defined on a screen thats missing from objects.txt? I'm not sure, does it say do the same with the default skin(carwings dyno lite)?
    Trying to narrow down if its skin related or app related.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  7. #57
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    I have tried it with carwings lite and carwings full and I still get the same results. I believe it may be the application itself causing the problem.
  8. #58
    Dec 2007
    I tried it.. didn't work.. i select the songs from an album.. it didn't load up into a playlist.. i minimized RR to check the foobar, its playlist is emty as well.. Tried it both auto and manual.
    i am gonna run debug to see what's going on.. I'll post it here..
    Quote Originally Posted by mitchjs View Post
    edit:
    10/4/2009 12:43:05 AM: Warning: Could not find Foobar2000 in the provided Path (C:\Program Files\foobar2000).
    but i noticed foobar2000 was launched every time i started RR, so that warning doesn't make sense. Am i suppose to use a different set of commands that i used to control winamp?
  9. #59
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    No. I recently DL'd the very latest foobar2000 v0.9.6.9 and tested the it against the 10/1/09 RR release and had no issues. I even installed foobar2000 right in RR's folder. I think that the issues has to do with the COM server part of foobar. Did a clean install of RR, installed foobar v0.9.6.9, and the COM Server from site listed in docs. Ran RRConfig and set the player to foobarRR (manaul) and its path.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #60
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by suavecito View Post
    Yep, I get it too...
    Will fix, and repost another one...
    Oh..lookie...there's one now....
    Attached Files Attached Files
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. RR 06-01-2009 Release
    By mitchjs in forum Road Runner
    Last Post: 07-03-2009, 01:39 AM
  2. XM works in Timetrax, not RR
    By bruha in forum Road Runner
    Last Post: 12-30-2006, 08:38 AM
  3. Next release (BETA 10) delayed
    By skippy76 in forum Road Runner
    Last Post: 11-24-2005, 11:29 PM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
