Guino,
Just so I clearly understand. I have a Silabs radio and travel often to unknown cities. Please explain to me in detail, how to load local stations into the RR Radio screen. Yes, I am asking to be spoonfed!!!!
*** Available now from here ****
A bunch of little things.. we wanted to get this out asap...
Foobar users, please check the foobar thread (Foobar2000 Player Plugin)
WOW!
First I want to thank everyone who reported and helped get us though all the changes in the last month's build...
We did alot of clean up in this build. Nailed the bugs introduced when going to full unicode support. One thing to note, Winamp Versions < 5.30 does not support unicode. and Nailed some bugs we introduced during our late night programming...
Some KEY fixes:
Albumart Indicator
Foobar Fixes
tagcache fix
Albumart
Horm fix(actually a resume.ini issue from 8/1)
Improved icon support on iLists work with PNG/GIF transparency (BLACK also works)
Fixed Silabs USBRadio.dll not using correct audio capture device
Standard list, when DL contains music type files, black bar appears on inital selection
Code:LEGEND: - = Removed + = Added * = Changed ! = Major code change # = bug fix ^ = Note 10/5/09 ------------------------------------------------------------------------------ # Path bug for plugin data path # Foobar2000 player, a few different issues # tagcache.ini not saving on exit + Added ONRBUTTON, ONMBUTTON events (Right/Middle Mouse Button Clicks) # SkinEditor bugs fixed, see skineditor history.txt * SkinTool updated v2.0, see skintool history.txt * RRconfig, Added wintvpath, closeplayeronexit settings 9/30/09 ------------------------------------------------------------------------------ + SKIN DEFINITION "IND" Indicator image modifier property, code improvement (see "new skin commands.txt") IND,NAME OF INDICATOR,PATH TO OFF IMAGE,PATH TO ON IMAGE Example: IND,SHUFFLE,Indicators\Shuffle_off.png,Indicators\Shuffle_on.png * Cleaned up "albumart" indicator code 9/29/09 ------------------------------------------------------------------------------ # Issues with older winamp versions that dont support unicode playlists # Tagache issue on restart 9/27/09 ------------------------------------------------------------------------------ # RRConfig, Foobar200 (Manual) setting # RRSkinEditor, couple of small fixes (see skin editor history for details) 9/24/09 ------------------------------------------------------------------------------ * Improved icon support on iLists work with PNG/GIF transparency (BLACK also works) # Standard list, when DL contains music type files, black bar appears on inital selection # Fixed Silabs USBRadio.dll not using correct audio capture device 9/23/09 ------------------------------------------------------------------------------ # fixed Albumart indicator (aka J skin definition) # fixed resume.ini processing at resume from HORM
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
Guino,
You can use the "LOCAL" command to switch the station list from normal to local.
Also the command "SEARCHPRESETS" search all frequencies and save the station in the local station list.
GizmoQ, johnnyS has it right
the command "SEARCHPRESETS" will automaticly put you into LOCAL list too
"LOADLIST;mycoollist.ini" will also load a station list into the LOCAL LIST
now, do u need me to explain how to drive to a different city? or we good![]()
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
I guess he wants something like this:
On your home city:
-Leave LOCAL mode OFF
-Add your home presets carefully (by hand to be sure)
When you leave town:
-Turn Local mode ON
-Use SEARCHPRESETS or add the local stations by hand (however you like)
When you go home again turn LOCAL mode off (your home stations should come back).
That's basically it.
Ride Runner RR's Myspace
aww yea birthday release thread![]()
Live mp3Car Facebook Chat
yayeah!
Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
Thanks, that's a start on what I was looking for. A single button with the command "SEARCHPRESETS" will automatically change the radio screen to local mode and search for and load all local radio stations as well as save them in a file "localradio.ini". I can then create an RRCode script to rename it and load it later using the LOADLIST command, but I have to switch to localmode manually first. Is that right?
For clarification, I have some more questions. Above what signal strength does this search occur? and can that level be adjusted? In what directory is the "localradio.ini" saved? If I don't switch to localmode first, will the LOADLIST of a saved "localradio.ini" over write the "radio.ini"? If I shut down the computer while listening to the radio in local mode, when I turn it back on will RR's radio still be in localmode still on the channel I was previously listening to? As I understand the above, the RADIO_MENU_FUNCTION.SKIN is no longer necessary - Please verify/confirm for me.
Thanks for the quick reply.
I'm sure this has been mentioned before, but are there any plans for RR to support MediaMonkey in the future?
My Worklog
My Mustang
2006 Tungsten Grey GT | Dark Charcoal Leather | 18" Fanblades | Spoiler Delete
C&L Intake | Bullitt Mufflers | MGW Short-throw Shifter | MGW Interior Pieces
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
