Results 1 to 6 of 6
Thread: VLCVidRR and dvd controls / TV
    Aug 2004
    Germany
    Hi. Got two question, one regarding DVD, one's about TV integration.
    1. I couldn't find any information on how to send dvd navigation (up/down/left/right/ok/back) commands to an internal player. The VLCVidRR plugin doesn't create a new process, which I could use as sendkey target. I want to use RideRunner as HTPC, so mouse is a no-go.
    2. The skin commands documentation says:
    "TV" - Loads the TV Skin/Plugin with preset channels (Same as "LOAD;TV.SKIN")
    What plugin ? This ? http://www.winamp.com/plugins/details/138360
    TV use doesn't seem to be documented very good. A little advice would really be appreciated (channel searching, tuning, recording? etc.)
    Constant Bitrate almera's Avatar
    Aug 2004
    Quote Originally Posted by Konrad View Post
    How do I setup TV / Camera Support ?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    1-Correct VLCVidRR is a plugin built-in RR's process. You can try sendkey without activate (as it's inside rr's window) but RR may get the keys first. I believe the ONLY plugin which would allow for making commands to up/down/ok menu items is MSVid.
    2-Yes, that is the correct plugin. It's mainly for Analog TV, but Digital TV works with SOME tuners.
    If I may suggest, you can get a wireless trackball or one of the Gyration Air Mouse/Remote devices -- this is the best thing for HTPC I have seen (I have one BTW) as it allows for operating ANY application on the PC.
    EDIT: You may be able to send keys to the alternative VLC plugin for 0.8.6.
    Ride Runner RR's Myspace
    Aug 2004
    Germany
    @almera: Thanks. I somehow missed the thread (the WinAMP TV plugin link in the thread is outdated, btw)
    @guino:
    1: That's sad. I'll try MSVid. Can't this feature be added to the other videoplayer plugins ?
    Just tested MSVid. Seems that plugin doesn't support ISO's, MPlayerC and VLC do, though.
    Also, just FYI (because I don't know if it's of any interest): MSVid always disables ClearType on my Windows7 desktop system, even after leaving RideRunner. I have to re-enable it manually.
    2: HOT ! A little expensive, though. I'm using the X10 v1 remote in combination with EventGhost.
    Aug 2004
    Here you go:
    Attached Files Attached Files
    Aug 2004
    Germany
    Thanks, but already got it . Wanted to point put that the link has to be updated.
