Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: Ride Runner "Reminder"
  1. #11
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Quote Originally Posted by trader007 View Post
    because if your gps puck has been off it can sometimes take up to 10min to lock a signal in.
    You need a new GPS, the BU353 takes less than 60 seconds for a cold lock
    RevFE
    My Shop
  2. #12
    Jan 2006
    say what? thats a feature i added to mine... pc starts when i remote start the truck, that way its all loaded up and working by the time i get in. also, i have the AUX button on my remote programmed to turn the pc on too for the times i want to quickly vnc into it without turning on the engine. works beautifully. i can even use the aux button to keep the pc from turning on with the engine if thats what i wish too...
    the remote start turn on is really nice too, because if your gps puck has been off it can sometimes take up to 10min to lock a signal in.
    Yea I dont see how having at pc start up with a remote start is a problem? Same voltage same everything. Also very handy, being that its all booted up and ready to go by the time you get in!
  3. #13
    May 2006
    Calgary, Alberta
    Your ignition and 12 volt lines on a car are separate and there's no reason for a remote starter to tap into the 12 volt line for any reason. It's like every time you start your car the left indicator turns on. The two are in no way related and shouldn't be functioning together. Obviously a wire is tapped in where it shouldn't be.
    I do realize however, that someone could have set it up purposely like this if they wanted it to happen for some reason, in which case it's fine.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  4. #14
    Jan 2006
    Quote Originally Posted by Maheriano View Post
    Yes, I installed my alarm and auto start intentionally running the 12v line, for two reasons. One so my carPc boots, and headunit turns on before I get into the car and two so my fog lights turn on when my car starts.
  5. #15
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Another thought might have been to have the blower on when the car was started to either cool/heat b4 you get in the car...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  6. #16
    Dec 2008
    remote starts have 200ma (-) outputs that activate when you hit the remote start. they are designed specifically to turn devices on with your remote starter. i have no idea what you mean by "they are not related"... every circuit in a car is the same power flow, they all go back to the same battery...
    yes, this is how the installation manual tells you how to install my remote start. this way, as long as you leave your heater on or a/c on when you get out of the car, it will start with the remote start. i never get into a cold truck in the winter, unless i forget to use the remote start.
  7. #17
    Jan 2006
    I do, In if its winter i leave the heat to full at night when i come home so when I get into the car in the morning its nice and toasty, and vice versa for the sumer!
  8. #18
    May 2008
    Bend, OR
    Please do not give indications on how to circumvent the reminder screen. - Enforcer
  9. #19
    May 2006
    Calgary, Alberta
    My HVAC comes on with my remote start but my computer doesn't.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  10. #20
    May 2006
    Calgary, Alberta
    By your logic everything would come on the second you supplied power to the 12 volt line. Your indicators, windshield wipers, everything. The difference is the switched line is behind some sort of relay or gate that only gives it power when the key is turned to/past ACC.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. Ride Runner front end
    By mav1989 in forum Road Runner
    Last Post: 05-06-2010, 09:48 AM
  2. My comprehensive guide to Road Runner and Flash
    By Sonicxtacy02 in forum RR Skins
    Last Post: 02-09-2010, 07:04 PM
  3. Ride Runner Article on Wikipedia
    By justchat_1 in forum Road Runner
    Last Post: 09-16-2009, 08:47 PM
  4. Ride Runner - lost my library button
    By chisel900 in forum Road Runner
    Last Post: 05-18-2009, 01:51 PM
  5. help on using ride runner
    By alexpez23 in forum Road Runner
    Last Post: 03-03-2009, 01:06 PM
