Results 1 to 4 of 4
Thread: Please help me...configuration
    Oct 2008
    Hello, first give you my congratulations for your work and the forum.
    I am writing to ask for help, I'm Spanish and I do not know much English and I took 4 months translating and reading post to learn how to handle the RR and DFx4 skin but I have some problems setting up a few things:
    Music......................OK
    Video......................OK
    DVD........................OK
    TV..........................OK
    Pictures...................OK
    Games.....................OK
    Browser...................OK
    Camera....................OK
    Media Copy..............OK
    Skin Colors...............OK
    Net Radio.................OK
    External APP.............OK
    Skins.......................OK
    Sys Dialog................OK
    Lyrics......................OK
    Taskman..................OK
    Theme.....................OK
    Mixer.......................OK
    RRRadar...................OK
    SygicDrive................OK
    Vehicle Maintenance...OK
    Scribble Pad..............OK
    Radio.....................OK but is more slow
    Weather.................OK but is not weather interactive
    Traficc Cams...........OK but is a different skin, I use the DFx4
    iGO8......................OK but CPU 90%
    Voice Control..........KO
    Phone....................KO
    Gas Price...............KO I'm trying configured to spain...I have found some databases to try when run skin
    Calendar................KO
    Wireless.................KO
    RRMedia.................KO
    Engenie Monitor.......KO
    Youtube.................KO
    Dun (Dial up)...........KO
    Mileage & Trip.........KO
    Netstrumbler...........KO
    Google Maps...........KO
    OBD II...................KO
    ORB......................KO I would like push button and go "https://my.orb.com/orb/" because the ORB Server is in my house
    Change in exit_menu.skin "Stanby" to "Monitor OFF" to power off monitor...if I can
    If your need any file to see the configuration tell me
    Please help me!!...I'm make me crazy...is so difficult in english for me
    More thanks.
    Moderator moves the post if this is not your site
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    > Please specify which radio you're using
    > The built-in weather is only for basic 5-day forecast, some skins provide radar images and animation forecast, but that's by script/plugin.
    > This is skin provided by plugin/script, with some work you should be able to copy the screen/plugin from one skin into the one you want.
    > Some GPS applications can really load up the CPU -- depends a lot on the hardware and GPS application.
    > http://www.mp3car.com/vbulletin/rr-p...cecontrol.html
    > .net Bluetooth Mobilephone Plugin
    Gauges..................KO
    > What kind of gauges ? For what purpose ?
    > Available in the US and UK only (as far as I know)
    > [ElcoLendar] RR Calendar |- Alpha -|
    > http://www.mp3car.com/vbulletin/rr-r...ger-1-5-a.html
    Jukebox.................KO
    > What kind of jukebox ?
    > http://www.mp3car.com/vbulletin/rr-r...hlight=rrmedia
    > RRTubeEx [Youtube Plugin]
    Dun.......................KO
    > Is this really Dial Up ? or what do you mean here ?
    Emu Console...........KO
    > Choose the emulator you want then - http://www.mp3car.com/vbulletin/rr-f...in-screen.html
    > http://www.mp3car.com/vbulletin/rr-r...ht=milage+trip
    > There are some scripts for netstumbler you can use to auto-search/connect, however, this is entirely done in netstumbler, but you can embed it in RR like the console emulator.
    Google Traffic.........KO
    > These two can only be done using favorites in the web browser or using the Google Earth Plugin - http://www.mp3car.com/vbulletin/rr-r...hlight=rrearth
    > Those are the same -- You'll need an external application and then run it embedded like the emulator.
    GPS_Acceleration....KO
    > What does that mean ?
    > You can do this by making a favorite in the web browser, or making the web browser home address the address you posted.
    The amount of stuff you're trying to put in the same machine seems to make no sense to me and you'll likely need some serious skinning and some serious hardware, not to say many of those require internet, which means you're better off getting a 24/7 cell-based internet.
    Ride Runner RR's Myspace
    Oct 2008
    More thanks guino!!!...reading more to learn
    Oct 2008
    Hello...
    ---I use WinTV analog + FM
    Weather.................OK but is not weather_interactive.skin
    ---I have tried this...and test with other datas...but not change nothing...and not embedded Weather Live map ok either
    ---Question: How do I change the default location & where it's zoomed to, and the zoom level for the weather radar?
    Solution: This has to be done manualy (for now at least) Open the Weather_Interactive.skin in notepad, and find this line:
    F,-14,-15,839,541,"WeatherMap.swf?&lat=26.61&long=-80.12&viewPortWidth=830&viewPortHeight=550&initial WeatherLayerType=radar&initialZoomLevel=8&wxAnimat eOnStart=true"
    Change the &Lat= &long= values (Bolded above) to your lat and lon. Optionally you can play with the zoom setting on the end of the line, to change the level the map is zoomed when you open it.
    ---I would like as this because I dont know to modify the skin...I will write to JohnWPB to can help me because I have seen skin's photos here
    ---http://www.mp3car.com/vbulletin/rr-released-plugins/124696-rrtrafficcam-traffic-flow-cameras-status-released-3.html#post1258285
    ---CPU is 90% when show the navigator screen (map)...when I go to the menu screen the CPU down to 30%
    ---Motherboard:
    Tipo de procesador VIA C7, 2000 MHz (10 x 200)
    Nombre de la Placa Base Jetway J7F2W(E)
    Chipset de la Placa Base VIA CN700
    Memoria del Sistema 960 MB (DDR2-533 DDR2 SDRAM)
    DIMM1: Kingston 1 GB DDR2-533
    Thanks guino...reading...
    JohnWPB...Can you help me with you DFx4?? I need a skin of some plugins...Because I dont know modify the skins to adapt to DFx4
  1. How to use a configuration file created by the Configurator with MDX
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 09-08-2008, 04:36 PM
  2. How to add a Digital Output instance to your configuration file
    Last Post: 06-07-2008, 11:20 AM
  3. Quick overview of the Fusion Control Centre MDX Configurator
    Last Post: 06-06-2008, 05:17 AM
  4. Service Configuration Files
    By Phatsacks in forum WinNT Based
    Last Post: 08-29-2007, 11:03 PM
  5. configuration
    By knubile in forum DigitalMods (Scripts / API)
    Last Post: 12-23-2006, 11:04 AM
