Results 1 to 8 of 8
Thread: Best way to launch URL direct from me
    Aug 2008
    I have searched but haven't been able to find this, and from reading the command documentation, it seems like it could be down a few different ways. I want to launch Firefox and have it load www.pandora.com from a menu button in DFX4 ( or any skin ). The web command isnt documented to take any URL parameters. I have tried loading the wbrowser.skin file and using the run command too. I can get Firefox to load but it never starts on the URL I want. I basically want to replicate typing "firefox www.pandora.com" in the windows Run box, and ideally have it load in the wbrowser.skin.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Pandora Radio Applett
    I do not know of a way to launch a URL into the browser either...
    Howerver
    I had been working on a Pandora radio app, that will embed it directly into the DFX skin. It is still a bit beta, but it does work well for me at least.
    Make sure you use Internet Explorer, and log into your Pandora account, and then you are all set. This only has to be done once to set the cookie for the browser.
    Read the Read Me.txt in the folder on where to put the file.
    Here is a screen cap of it in action:
    I also made another small applet for Slacker Radio, it is available HERE.
    Attached Files Attached Files
    My Fiero Build Thread
    Aug 2008
    Thanks JohnWPB. There is a standalone Pandora player called Pandora's Jar. I used to use it, but found it a little unstable. I was considering launching that as an app, but this is preferred. I just installed it and it worked. Few things I noticed. The app/music does not stop when I go back to the main menu, or even when I exit Ride Runner. Many parts of the screen are blank sometimes and alt + tab and moving the mouse sometimes fixed this. Music plays fine, which is the most important part. Thanks again.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Yea, this is beta for sure... I can easily add a couple of things to it.
    I could make it exit when you leave the screen, or put a "Close Pandora" button on the pandora skin.
    I didn't have it close when you left the screen, as most of the time you would probably like to be able to use other things in the skin while listening to music (GPS, Scheduler, Traffic and so forth).
    Aug 2008
    I agree. It should definitely stop when RR exits. Anything else would be best left to a button or a config option. Is the plugin actually going to pandora.com or did you package the swf in something self contained. It would be great to be able to communicate with the program, i.e. pause, next track, thumbs up, thumbs down. Probably not easy with flash tho. Maybe it could be done based off screen coordinates.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    To go back to the original post, I don't know if this works for Firefox, but it does ifor IE.
    Have a button
    B,x,y,w,h,"web||weburl;www.websiteurltogoto.com"," "
    Aug 2008
    Thanks Enforcer! I will try it when I get home.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    The Plugin, is not really a "Plugin" really. It is an autoit script that trims the Pandora web page to fit into the area in the skin. There is no real way to communicate with it from RR unfortunately.
    I will add a button on the Pandora skin to close it.
  1. MSN Direct
    By UnusuallyGenius in forum Wireless Communications
    Last Post: 10-09-2009, 03:32 PM
  2. XM Direct 2 Serial Cable
    By 73Novaboy in forum General Hardware Discussion
    Last Post: 12-02-2008, 01:23 PM
  3. help with launch command/vairable
    By 3square in forum Road Runner
    Last Post: 07-16-2007, 05:09 PM
  4. Replies: 8
    Last Post: 02-10-2005, 07:40 PM
  5. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 02:21 AM
