Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: Pause music on Sygic Drive directions
  1. #11
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by anuchit View Post
    Please try this I creat command myself
    install foo_runcmd.dll f2k components
    use this command lines in exectbl.ini
    "NAVPAUSE","run;C:\Program Files\foobar2000\foobar2000.exe" /runcmd="Playback/pause"
    "NAVRESUME","run;C:\Program Files\foobar2000\foobar2000.exe" /runcmd="Playback/play"
    Its work for me
    If u want to use pause and play to smooth sound u should set fading (ms) in preference > advance > playback option of f2k
    Do you have a link for foo_runcmd.dll ?
    Is it possible to have not a pause for NAVPAUSE but a volume lower ?
    Jun 2007
    download..this for components for f2k 0.9.x.x
    http://www.mediafire.com/?ttgnzjzgjkz
  3. #13
    May 2008
    Bordeaux, France
    Smile
    Very good job !
    the plugin run very well, but is iy possible to have not a full mute with NAVPAUSE but
    to define the volume at 40% by exemple ?
    by exemple two commands like that would be cool :
    "NAVPAUSE","run;C:\Program Files\foobar2000\foobar2000.exe" /runcmd="Volume/40"
    "NAVRESUME","run;C:\Program Files\foobar2000\foobar2000.exe" /runcmd="Volume/100"
    I think, that it was a good think to put your plugin's link in the RR foobar2000 thread .
  4. #14
    Jun 2007
    Quote Originally Posted by pierrotm777 View Post
    Very good job !
    Thank for suggest command But your this example command not work for me..
  5. #15
    May 2008
    Bordeaux, France
    It's normal. These commands don't exist.
    But how to do that
  6. #16
    Oct 2004
    Israel
    I'm not using Foobar but I think this would help you :
    http://wiki.hydrogenaudio.org/index....mandline_Guide
    Volume related :
    Playback/Set volume to 0dB
    Playback/Set volume to -12dB
    Playback/Set volume to -15dB
    Playback/Set volume to -18dB
    Playback/Set volume to -21dB
    Playback/Set volume to -3dB
    Playback/Set volume to -6dB
    Playback/Set volume to -9dB
    Playback/Volume down
    Playback/Volume mute
    Playback/Volume up
    Enjoy !
    HeadUnit : Car-Pc | Processor : JBL MS-8 | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Tang-Band Ceramic 25-1719S | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI , SPL AB03445 | Wiring : Sommer , Neutrik
  7. #17
    May 2008
    Bordeaux, France
    I have tried these options:
    these run well:
    Code:
    Playback/Volume up
    these don't run:
    Code:
  8. #18
    Oct 2004
    Israel
    I checked it and you are right , It seems to be disabled in 0.9
    But Volume up / down is working , So you can use that
    And create a batch / autoit script that run something like 7-8 of volume down and up commands
    I did it , And it works pretty good and you even get the whole gradually volume change
    I know its a little ghetooish but it works
  9. #19
    May 2008
    Bordeaux, France
    I have tried that:
    Code:
    "NAVPAUSE","run;C:\Program Files\Ride Runner\Skins\Carwings_Dynamic_pm\Scripts\foobar2000down.bat"
    and that in the foobar2000down.bat:
    Code:
    C:\Program Files\foobar2000\foobar2000.exe /runcmd=Playback/Volume down
    That don't run
  10. #20
    Oct 2004
    Israel
    Use this :
    Code:
    "C:\Program Files\foobar2000\foobar2000.exe" /runcmd="Playback/volume down"
  1. Music not muting when iGuidance gives directions
    By ctsoccer13 in forum Road Runner
    Last Post: 10-21-2007, 06:49 PM
  2. Replies: 18
    Last Post: 10-15-2007, 08:21 AM
  3. iGuidance migration pause music..
    By popi79 in forum Road Runner
    Last Post: 08-10-2007, 11:23 PM
  4. My hard drive situation
    By PhatHam in forum Newbie
    Last Post: 10-26-2006, 12:50 PM
  5. External notebook hard drive help
    By mtmsol in forum General Hardware Discussion
    Last Post: 04-18-2002, 12:24 PM
