Results 21 to 30 of 31
Thread: Pause music on Sygic Drive directions
  1. #21
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Now i have that for down:
    foobar2000down.bat
    Code:
    "C:\Program Files\foobar2000\foobar2000.exe" /runcmd="Playback/volume down"
    and that for up:
    foobar2000up.bat
    Code:
    "C:\Program Files\foobar2000\foobar2000.exe" /runcmd="Playback/volume up"
    and in the exectbl.ini file:
    Code:
    "NAVPAUSE","run;C:\Program Files\Ride Runner\Skins\Carwings_Dynamic_pm\Scripts\foobar2000down.bat"
    "NAVRESUME","run;C:\Program Files\Ride Runner\Skins\Carwings_Dynamic_pm\Scripts\foobar2000up.bat"
    But it is very too slow !
    But all run
  2. #22
    May 2008
    Bordeaux, France
    Smile
    I think that would be a good idea to add the foo_runcmd.dll in the RR install .
    Guino ? What do you think about ?
  3. #23
    Oct 2004
    Israel
    OK I found a solution for you
    Download this component :
    http://www.hydrogenaudio.org/forums/...howtopic=49589
    And create an event like here :
    http://www.hydrogenaudio.org/forums/...hp/t75385.html
    Then call it using runcmd
    I've tried it and it works perfectly
    HeadUnit : Car-Pc | Processor : JBL MS-8 | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Tang-Band Ceramic 25-1719S | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI , SPL AB03445 | Wiring : Sommer , Neutrik
  4. #24
    Jun 2007
    Thank you Madboy
    Please show me for example command on exectpl.ini for this
    I not good commander
  5. #25
    May 2008
    Bordeaux, France
    My setup foobar:
    I have that on foobar
    and that on exectbl.ini file:
    Code:
    "NAVPAUSE","run;C:\Program Files\foobar2000\foobar2000.exe" /runcmd="Playback/Set volume to -3 dB"
    "NAVRESUME","run;C:\Program Files\foobar2000\foobar2000.exe" /runcmd="Playback/Set volume to 0 dB"
    That don't run for me
  6. #26
    Jan 2006
    Sorry to threadjack, but will your dll also be able to send street name indicator codes to RR?
  7. #27
    Oct 2004
    Israel
    anuchit & pierrtom777 -
    First create an event on Prefernces - Schedular ( Look at the event list ) :
    1.Press on "add"
    2.Add menu item event
    3.Call it for example "ATT" , And choose "re-enable after done"
    Then create an action on action lists :
    1.Press on "add"
    2.Call It "ATT"
    3.Right-click on ATT in the list and "Add action"
    4."Set volume"
    5.Set foobar's volume on whatever you want and press on "Pick"
    6.Set "Use fade" if you wish
    Now go back to the event's list :
    1.Right-click on the ATT's event
    2."Assign action list"
    3."ATT"
    You are done
    Now you can run it with :
    Code:
    "C:\Program Files\foobar2000\foobar2000.exe" /runcmd="ATT"
  8. #28
    Jun 2007
    Thank you Madboy for step by step..
    Its work very well
    "NAVPAUSE","run;C:\Program Files\foobar2000\foobar2000.exe" /runcmd="ATT"
    "NAVRESUME","run;C:\Program Files\foobar2000\foobar2000.exe" /runcmd="CURRENT VOL"
  9. #29
    May 2008
    Bordeaux, France
    This is ok for me also
    This is my setup
    Code:
    It is a very good job
    May 2008
    Bordeaux, France
    For some guys that want to use now the foobar2000 player and have a mute function when the gps give a sentence , it's now possible without adding something.
    Just do that:
    I think that i have your solution.
    Try that link please, Navmute.zip .
    -I put all files in the program folder (where also Drive.exe resides).
    -Then I opened a command prompt and typed "setdll.exe -d:NavMute.dll Drive.exe" or create a cmd file : create a backup of your drive.exe file before !!!!
    That's all. Sygic now sends the commands "NAVPAUSE" and "NAVRESUME" to RR
    to add in your exectbl.ini :
    "NAVPAUSE","PAUSE||SETVOL;Player;100"
    "NAVRESUME","SETVOL;Player;255||RESUME"
    or just:
    "NAVPAUSE","SETVOL;Player;50"
    "NAVRESUME","SETVOL;Player;255"
    If you use the RRextended plugin, the better solution is:
    "NAVPAUSE","RRVolRamper_Dn;75;30||Wait;2"
    "NAVRESUME","RRVolRamper_Up;100;30
    I have tested the mute option with on Sygic Drive or Fleet, Igo8 and Garmin Mobile Pc and run very well .
  1. Music not muting when iGuidance gives directions
    By ctsoccer13 in forum Road Runner
    Last Post: 10-21-2007, 06:49 PM
  2. Replies: 18
    Last Post: 10-15-2007, 08:21 AM
  3. iGuidance migration pause music..
    By popi79 in forum Road Runner
    Last Post: 08-10-2007, 11:23 PM
  4. My hard drive situation
    By PhatHam in forum Newbie
    Last Post: 10-26-2006, 12:50 PM
  5. External notebook hard drive help
    By mtmsol in forum General Hardware Discussion
    Last Post: 04-18-2002, 12:24 PM
