is it wired right???!!
prob not
it has to be on when the PC is ON
which is usually NOT to the accessory position in the KEY
I have the USB ALPS1 Sirius setup. When it resumes there's no sound, in addition, at the top of the screen where the channel number and program description are displayed it will display the same channel number as before hibernation, but the description for channel one is displayed. The signal strength bar is stuck at whatever it was when it hibernated, I can scroll the channel list but I can't change the channel. I have to exit and restart RR to get it all to work properly again. Any ideas?
Thanks!
Chris
prob not
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
It gets it's power from the same relay that turns the PC on, they both get their power turned on and off at the same time. The relay is connected to the RUN side of the ignition switch and has constant power when the key is in any position except OFF. There's a timer on the relay that gives the PC enough time to shut itself down so the ALPS1 gets power as soon as the PC gets power and it has power for a little while after the PC is done hibernating. Should I just wire the ALPS1 to be always on?
it has to be on when the pc is ON
so... if its on that timer, its ok...
but make sure... if it shuts off duing the hibernation process, most likely it will cause communication to fail...
also make sure RR is HibernationAware
i would turn on sirius debugging, and post me a debug.txt file
from a session of a complete hibernation cycle
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
How do I turn on sirius debugging and where would I find the resulting txt file? I searched and didn't have much luck.
use RRCONFIG... or manually edit rr.ini
there is debugging options on page 4
turn it on, fresh, and sirius
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
There's a debug option in RRConfig, just check it+save, run RR do whatever and check the folder for the log files.
Ride Runner RR's Myspace
I did a clean boot, started RR, opened sirius and then hibernated and resumed
here's the debug with an older ver of RR-
10/15/2009 1:49:54 PM: Start -- Version: 1/24/2009
10/15/2009 1:49:55 PM: Master Vol: Volume Control/4
10/15/2009 1:49:55 PM: GetLineControl Failed: 401
10/15/2009 1:49:55 PM: No Treble Support
10/15/2009 1:49:55 PM: No Bass Support
10/15/2009 1:49:55 PM: No Master ON/OFF
10/15/2009 1:49:55 PM: Source: Wave=&H1008/1
10/15/2009 1:49:55 PM: Source: SW Synth=&H1004/2
10/15/2009 1:49:55 PM: Source: Microphone=&H1003/3
10/15/2009 1:49:55 PM: Source: CD Player=&H1005/4
10/15/2009 1:49:55 PM: Source: Aux=&H100A/5
10/15/2009 1:49:55 PM: Source: Line In=&H1002/6
10/15/2009 1:49:55 PM: Shell: "C:\Program Files\RideRunner\gamma\gapa.exe"
10/15/2009 1:49:55 PM: Sim.WMSGs: 1
10/15/2009 1:49:55 PM: Sim.WMSGs: 2
10/15/2009 1:49:56 PM: Enter Exec: False, menu.skin, , False
10/15/2009 1:49:56 PM: Que Exec: True, menu.skin, "ONSKINSTART", False
10/15/2009 1:49:56 PM: Executing: ONSKINSTART
10/15/2009 1:49:56 PM: Leave Exec: False, menu.skin, ONSKINSTART, False
10/15/2009 1:49:56 PM: Que Exec: True, menu.skin, "ONSONGSTART", False
10/15/2009 1:49:56 PM: Executing: ONSONGSTART
10/15/2009 1:49:56 PM: Leave Exec: False, menu.skin, ONSONGSTART, False
10/15/2009 1:49:58 PM: Enter Exec: False, menu.skin, "sirius", False
10/15/2009 1:49:58 PM: Que Exec: True, menu.skin, "sirius", False
10/15/2009 1:49:58 PM: Executing: sirius
10/15/2009 1:49:58 PM: Leave Exec: False, menu.skin, load;sirius.skin;SIRIUS, False
10/15/2009 1:49:59 PM: Enter Exec: False, sirius.skin, , False
10/15/2009 1:49:59 PM: Que Exec: True, sirius.skin, "ONSONGSTART", False
10/15/2009 1:49:59 PM: Executing: ONSONGSTART
10/15/2009 1:49:59 PM: Leave Exec: False, sirius.skin, ONSONGSTART, False
10/15/2009 1:50:09 PM: Enter Exec: False, sirius.skin, , False
10/15/2009 1:50:09 PM: Que Exec: True, sirius.skin, "ONSONGSTART", False
10/15/2009 1:50:09 PM: Executing: ONSONGSTART
10/15/2009 1:50:09 PM: Leave Exec: False, sirius.skin, ONSONGSTART, False
10/15/2009 1:53:17 PM: Enter Exec: False, sirius.skin, , False
10/15/2009 1:53:17 PM: Que Exec: True, sirius.skin, "ONSONGSTART", False
10/15/2009 1:53:17 PM: Executing: ONSONGSTART
10/15/2009 1:53:17 PM: Leave Exec: False, sirius.skin, ONSONGSTART, False
10/15/2009 1:55:16 PM: Enter Exec: False, sirius.skin, "EXIT", False
10/15/2009 1:55:16 PM: Que Exec: True, sirius.skin, "EXIT", False
10/15/2009 1:55:16 PM: Executing: EXIT
10/15/2009 1:55:16 PM: Leave Exec: False, sirius.skin, load;menu.skin, False
10/15/2009 1:55:17 PM: Enter Exec: False, menu.skin, "EXIT", False
10/15/2009 1:55:17 PM: Que Exec: True, menu.skin, "EXIT", False
10/15/2009 1:55:17 PM: Executing: EXIT
10/15/2009 1:55:18 PM: Leave Exec: False, menu.skin, menu;exit_menu.skin, False
10/15/2009 1:55:18 PM: Enter Exec: False, exit_menu.skin, "QUIT", False
10/15/2009 1:55:18 PM: Que Exec: True, exit_menu.skin, "QUIT", False
10/15/2009 1:55:18 PM: Executing: QUIT
10/15/2009 1:55:19 PM: Shutdown
Here's the new RR ver-
10/15/2009 2:04:42 PM: Start -- Version: 10/5/2009
10/15/2009 2:04:42 PM: OS Type: Windows XP
10/15/2009 2:04:42 PM: FileManager: FileMode = Legacy
10/15/2009 2:04:42 PM: FileManager: mypath = C:\Program Files\RideRunner\
10/15/2009 2:04:42 PM: FileManager: ProfilePath = C:\Documents and Settings\Chris Krug\My Documents\RideRunner\
10/15/2009 2:04:42 PM: SR---> Set object successful
10/15/2009 2:04:42 PM: SR---> SRLoadIn: SRcache.ini, SRLastChannel=132
10/15/2009 2:04:42 PM: SR---> SRLoadIn: SRcache.ini, Cache Loaded, Number of SRStations=128
10/15/2009 2:04:42 PM: SR---> SRLoadIn: Completed
10/15/2009 2:04:42 PM: SR---> SRPowerON: Port Open Attempt
10/15/2009 2:04:42 PM: Master Vol: Volume Control/4
10/15/2009 2:04:42 PM: GetLineControl Failed: 401
10/15/2009 2:04:42 PM: No Treble Support
10/15/2009 2:04:42 PM: No Bass Support
10/15/2009 2:04:42 PM: No Master ON/OFF
10/15/2009 2:04:42 PM: Source: Wave=&H1008/1
10/15/2009 2:04:42 PM: Source: SW Synth=&H1004/2
10/15/2009 2:04:42 PM: Source: Microphone=&H1003/3
10/15/2009 2:04:42 PM: Source: CD Player=&H1005/4
10/15/2009 2:04:42 PM: Source: Aux=&H100A/5
10/15/2009 2:04:42 PM: Source: Line In=&H1002/6
10/15/2009 2:04:42 PM: PLAYER: Winamp Version: 2.05
10/15/2009 2:04:42 PM: DirectDraw Count: 2 - [] [{67685559-3106-11D0-B971-00AA00342F9F}]
10/15/2009 2:04:42 PM: No Phidgets interface detected.
10/15/2009 2:04:42 PM: Plugin Manager: loading Global Plugins...
10/15/2009 2:04:42 PM: Plugin Manager: loading Global Plugins Completed.
10/15/2009 2:04:42 PM: LoadSkin: C:\Program Files\RideRunner\Skins\BMV2\
10/15/2009 2:04:42 PM: Plugin Manager: loading SkinDir Plugins...
10/15/2009 2:04:42 PM: Plugin Manager: loading SkinDir Plugins Completed.
10/15/2009 2:04:42 PM: CheckResume: ResumeMusic=1 WasRadio=0
10/15/2009 2:04:42 PM: CheckResume: Resuming to music player: PLPosition=0 TrackPosition=5670
10/15/2009 2:04:43 PM: SR---> FindRadioProgress:BEGIN:
10/15/2009 2:04:43 PM: SR---> FindRadioProgress:START: COM9:
10/15/2009 2:04:43 PM: SR---> FindRadioProgress:RESET: COM9:
10/15/2009 2:04:43 PM: Enter Exec: False, menu.skin, , False
10/15/2009 2:04:43 PM: Que Exec: True, menu.skin, "ONSKINSTART", False
10/15/2009 2:04:43 PM: Que Exec: True, menu.skin, "ONSOURCECHANGE", False
10/15/2009 2:04:43 PM: Leave Exec: False, menu.skin, ONSOURCECHANGE, False
10/15/2009 2:04:43 PM: Que Exec: True, menu.skin, "ONSONGSTART", False
10/15/2009 2:04:43 PM: Leave Exec: False, menu.skin, ONSONGSTART, False
10/15/2009 2:04:43 PM: SR---> FindRadioProgress:FOUND: COM9:
10/15/2009 2:04:43 PM: SR---> FindRadioProgress:COMPLETE:
10/15/2009 2:04:43 PM: SR---> oSR_SiriusEventPortOpened: .PowerOn
10/15/2009 2:04:45 PM: Enter Exec: False, menu.skin, "ONBTNPRESS||sirius", False
10/15/2009 2:04:45 PM: Que Exec: True, menu.skin, "ONBTNPRESS||sirius", False
10/15/2009 2:04:45 PM: Que Exec: True, menu.skin, "sirius", False
10/15/2009 2:04:45 PM: Executing: sirius
10/15/2009 2:04:45 PM: SR---> SRActive:
10/15/2009 2:04:45 PM: SR---> SRActive: Not powered on (yet)...
10/15/2009 2:04:45 PM: Que Exec: True, sirius.skin, "ONSCREENCHANGE", False
10/15/2009 2:04:45 PM: Que Exec: True, sirius.skin, "ONSOURCECHANGE", False
10/15/2009 2:04:45 PM: Leave Exec: False, sirius.skin, ONSOURCECHANGE, False
10/15/2009 2:04:45 PM: SR---> oSR_SiriusEventRadioReady:
10/15/2009 2:04:45 PM: SR---> SRPoweredON: SRON=True,SRTuneTo=132
10/15/2009 2:04:45 PM: SR---> SRActive: Tune to...132
10/15/2009 2:04:46 PM: Enter Exec: False, sirius.skin, , False
10/15/2009 2:04:46 PM: Que Exec: True, sirius.skin, "ONSONGSTART", False
10/15/2009 2:04:46 PM: Leave Exec: False, sirius.skin, ONSONGSTART, False
10/15/2009 2:04:46 PM: SR---> oSR_SiriusEventVBChannelChanged:
10/15/2009 2:04:52 PM: SR---> oSR_SiriusEventAntennaStatus
10/15/2009 2:04:52 PM: SR---> Radio channel active = 132
10/15/2009 2:04:58 PM: Enter Exec: False, sirius.skin, , False
10/15/2009 2:04:58 PM: Que Exec: True, sirius.skin, "ONSONGSTART", False
10/15/2009 2:04:58 PM: Leave Exec: False, sirius.skin, ONSONGSTART, False
10/15/2009 2:05:01 PM: SR---> Radio FULL Channel Fetch done
10/15/2009 2:09:06 PM: WM_POWERBROADCAST: wParam=6
10/15/2009 2:09:06 PM: WM_POWERBROADCAST: wParam=PBT_APMRESUMEAUTOMATIC
10/15/2009 2:09:07 PM: WM_POWERBROADCAST: wParam=6
10/15/2009 2:09:07 PM: WM_POWERBROADCAST: wParam=PBT_APMRESUMEAUTOMATIC
10/15/2009 2:09:21 PM: Enter Exec: False, sirius.skin, "ONBTNPRESS||EXIT", False
10/15/2009 2:09:21 PM: Que Exec: True, sirius.skin, "ONBTNPRESS||EXIT", False
10/15/2009 2:09:21 PM: Que Exec: True, sirius.skin, "EXIT", False
10/15/2009 2:09:21 PM: Executing: EXIT
10/15/2009 2:09:21 PM: Enter Exec: True, menu.skin, , False
10/15/2009 2:09:21 PM: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
10/15/2009 2:09:21 PM: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
10/15/2009 2:09:23 PM: Enter Exec: False, menu.skin, "ONBTNPRESS||AUDIO", False
10/15/2009 2:09:23 PM: Que Exec: True, menu.skin, "ONBTNPRESS||AUDIO", False
10/15/2009 2:09:23 PM: Que Exec: True, menu.skin, "AUDIO", False
10/15/2009 2:09:23 PM: Executing: AUDIO
10/15/2009 2:09:24 PM: SR---> SRInActive:
10/15/2009 2:09:24 PM: SR---> SRMute: .MuteOn
10/15/2009 2:09:24 PM: SR---> SRInActive: SRON=False
10/15/2009 2:09:24 PM: Enter Exec: True, audio_player.skin, , False
10/15/2009 2:09:24 PM: Que Exec: True, audio_player.skin, "ONSCREENCHANGE", False
10/15/2009 2:09:24 PM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
10/15/2009 2:09:24 PM: Que Exec: True, audio_player.skin, "ONSOURCECHANGE", False
10/15/2009 2:09:24 PM: Leave Exec: False, audio_player.skin, ONSOURCECHANGE, False
10/15/2009 2:09:24 PM: Enter Exec: False, audio_player.skin, , False
10/15/2009 2:09:24 PM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
10/15/2009 2:09:29 PM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||PLAY", False
10/15/2009 2:09:29 PM: Que Exec: True, audio_player.skin, "ONBTNPRESS||PLAY", False
10/15/2009 2:09:29 PM: Que Exec: True, audio_player.skin, "PLAY", False
10/15/2009 2:09:29 PM: Executing: PLAY
10/15/2009 2:09:29 PM: Leave Exec: False, audio_player.skin, play, False
10/15/2009 2:09:31 PM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||EXIT", False
10/15/2009 2:09:31 PM: Que Exec: True, audio_player.skin, "ONBTNPRESS||EXIT", False
10/15/2009 2:09:31 PM: Que Exec: True, audio_player.skin, "EXIT", False
10/15/2009 2:09:31 PM: Executing: EXIT
10/15/2009 2:09:31 PM: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
10/15/2009 2:09:31 PM: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
10/15/2009 2:09:32 PM: Enter Exec: False, menu.skin, "ONBTNPRESS||sirius", False
10/15/2009 2:09:32 PM: Que Exec: True, menu.skin, "ONBTNPRESS||sirius", False
10/15/2009 2:09:32 PM: Que Exec: True, menu.skin, "sirius", False
10/15/2009 2:09:32 PM: Executing: sirius
10/15/2009 2:09:32 PM: SR---> SRActive:
10/15/2009 2:09:32 PM: SR---> SRMute: .MuteOff
10/15/2009 2:09:32 PM: Que Exec: True, sirius.skin, "ONSCREENCHANGE", False
10/15/2009 2:09:32 PM: Que Exec: True, sirius.skin, "ONSOURCECHANGE", False
10/15/2009 2:09:32 PM: Leave Exec: False, sirius.skin, ONSOURCECHANGE, False
10/15/2009 2:09:33 PM: Enter Exec: False, sirius.skin, , False
10/15/2009 2:09:33 PM: Que Exec: True, sirius.skin, "ONSONGSTART", False
10/15/2009 2:09:33 PM: Leave Exec: False, sirius.skin, ONSONGSTART, False
10/15/2009 2:09:36 PM: Enter Exec: False, sirius.skin, "ONBTNPRESS||VOL+", False
10/15/2009 2:09:36 PM: Que Exec: True, sirius.skin, "ONBTNPRESS||VOL+", False
10/15/2009 2:09:36 PM: Que Exec: True, sirius.skin, "VOL+", False
10/15/2009 2:09:36 PM: Executing: VOL+
10/15/2009 2:09:36 PM: Leave Exec: False, sirius.skin, VOL+, False
10/15/2009 2:09:37 PM: Enter Exec: False, sirius.skin, "ONBTNPRESS||VOL+", False
10/15/2009 2:09:37 PM: Que Exec: True, sirius.skin, "ONBTNPRESS||VOL+", False
10/15/2009 2:09:37 PM: Que Exec: True, sirius.skin, "VOL+", False
10/15/2009 2:09:37 PM: Executing: VOL+
10/15/2009 2:09:37 PM: Leave Exec: False, sirius.skin, VOL+, False
10/15/2009 2:09:50 PM: Enter Exec: False, sirius.skin, "ONBTNPRESS||PGUP", False
10/15/2009 2:09:50 PM: Que Exec: True, sirius.skin, "ONBTNPRESS||PGUP", False
10/15/2009 2:09:50 PM: Que Exec: True, sirius.skin, "PGUP", False
10/15/2009 2:09:50 PM: Executing: PGUP
10/15/2009 2:09:50 PM: Leave Exec: False, sirius.skin, PGUP, False
10/15/2009 2:09:53 PM: Enter Exec: False, sirius.skin, "ONBTNPRESS||PLAY", False
10/15/2009 2:09:53 PM: Que Exec: True, sirius.skin, "ONBTNPRESS||PLAY", False
10/15/2009 2:09:53 PM: Que Exec: True, sirius.skin, "PLAY", False
10/15/2009 2:09:53 PM: Executing: PLAY
10/15/2009 2:09:53 PM: Leave Exec: False, sirius.skin, play, False
10/15/2009 2:10:00 PM: Enter Exec: False, sirius.skin, "ONBTNPRESS||EXIT", False
10/15/2009 2:10:00 PM: Que Exec: True, sirius.skin, "ONBTNPRESS||EXIT", False
10/15/2009 2:10:00 PM: Que Exec: True, sirius.skin, "EXIT", False
10/15/2009 2:10:00 PM: Executing: EXIT
10/15/2009 2:10:00 PM: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
10/15/2009 2:10:00 PM: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
10/15/2009 2:10:02 PM: Enter Exec: False, menu.skin, "ONBTNPRESS||MINIMIZE", False
10/15/2009 2:10:02 PM: Que Exec: True, menu.skin, "ONBTNPRESS||MINIMIZE", False
10/15/2009 2:10:02 PM: Que Exec: True, menu.skin, "MINIMIZE", False
10/15/2009 2:10:02 PM: Executing: MINIMIZE
10/15/2009 2:10:02 PM: Leave Exec: False, menu.skin, MINIMIZE, False
just attach the files next time
there is NOTHING of use in what u posted...
there is no hibernation or resume...
just a startup
and from that its working fine![]()
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
Here's another try. i started up RR, started sirus and it played. At appx 8:06 I hibernated and as soon as it shut down I restarted it and it resumed. When it resumed it was still on the sirius screen and the time was 8:08 but srius was locked up as described above again. You can see in the log that there's a gap in time between these 2 lines-
10/15/2009 8:06:13 PM: Leave Exec: False, sirius.skin, ONSONGSTART, False
10/15/2009 8:07:49 PM: WM_POWERBROADCAST: wParam=6
That's when it was hibernating.
I also attached my rr.ini file
please look at the attached and see if you can help.
Chris
