View Poll Results: Do you like this program
Voters
14. You may not vote on this poll
  • Yes
    13 92.86%
  • No
    1 7.14%
Page 4 of 11 FirstFirst 1234567891011 LastLast
Results 31 to 40 of 108
Thread: GoogleMaps & Microsoft Virtual Earth & Google Sky
  1. #31
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile New update 0.9 ...
    I have updated the GoogleTraffic.exe .
    It is very faster that the older 0.6 version.
    It run alone, without other exe .
    Also, you can delete the gt1.exe,gt2*.exe,gt3*.exe,wheelup.exe,wheeldown.ex e and clickright.exe .
    Thanks to Guino for his help .
  2. #32
    May 2008
    Bordeaux, France
    Smile update 1.0
    Please see post #1 for an update .
    I have found a little bug . When RR is closed, now , GoogleTraffic is closed also .
    Good use .
  3. #33
    May 2008
    Bordeaux, France
    Smile Google Sky
    Several days ago, i have found this link , Google Sky .
    Also, I have adapted the John's script to see this link in RR .
    I wish you a good use !
  4. #34
    Raw Wave
    Jun 2002
    Virginia
    Pierrot,
    Thank you for your work on this. It looks great and I am trying to get it to work. I am having a problem with GoogleTraffic. I have followed all of the instructions to install. When I click the button in RideRunner to load GoogleTraffic the skin loads but I get the following message:
    "Autoit Error
    Line: -1:
    Error: Variable used without being declared."
    I'm using:
    Windows Xp SP3
    Riderunner 02/10/2010
    DFX4.0
    Carwings skins supplied with your plugin.
    Any idea what's going on?
    Thanks.
    Kevin
  5. #35
    May 2008
    Bordeaux, France
    Smile
    Can you run skintool befor to launch the GoogleTraffic screen an upload me your log ?
  6. #36
    Raw Wave
    Jun 2002
    Virginia
    Here you go. I noticed the second "\" before "Scripts" and thought that might be the problem, but when I changed the command to show the direct path the problem remained.
    ONBTNPRESS
    BYVAR;MAINBUTTON12;MyApp01<<MyApp02<<MyApp03<<MyAp p04<<MyApp05<<MyApp06<<MyApp07<<MyApp08<<MyApp09<< MyApp10<<MyApp11<<MyApp12<<MyApp13<<MyApp14<<MyApp 15<<MyApp16<<MyApp17<<MyApp18<<MyApp19<<MyApp20<<M yApp21<<MyApp22<<MyApp23<<MyApp24<<MyApp25<<MyApp2 6<<MyApp27<<MyApp28<<MyApp29<<MyApp30<<MyApp31<<My App32<<MyApp33<<MyApp34<<MyApp35<<MyApp36<<MyApp37 <<MyApp38<<MyApp39<<MyApp40<<MyApp41<<MyApp42<<MyA pp43<<MyApp44<<MyApp45<<MyApp46<<MyApp47<<MyApp48< <MyApp49<<MyApp50<<MyApp51<<MyApp52<<MyApp53<<MyAp p54<<MyApp55<<MyApp56<<MyApp57<<MyApp58<<MyApp59<< MyApp60<<MyApp61<<MyApp62<<MyApp63<<MyApp64<<MyApp 65<<MyApp66<<MyApp67<<MyApp68<<MyApp69<<MyApp70<<M yApp71<<MyApp72<<MyApp73<<MyApp74<<MyApp75<<MyApp7 6<<MyApp77<<MyApp78<<MyApp79<<MyApp80<<MyApp81
    load;rrtraffic.skin
    ONSCREENCHANGE
    RUN;C:\Program Files\RideRunner\Skins\DigitalFX 4.0\\Scripts\GoogleTraffic\GoogleTraffic.exe;Googl eTraffic
    SETTOPMOST;RR;false
    ONEXIT
  7. #37
    May 2008
    Bordeaux, France
    Quote Originally Posted by kbreeden View Post
    ONBTNPRESS
    load;rrtraffic.skin
    ONSCREENCHANGE
    SETTOPMOST;RR;false
    ONEXIT
    Replace that
    Code:
    RUN;C:\Program Files\RideRunner\Skins\DigitalFX 4.0\\Scripts\GoogleTraffic\GoogleTraffic.exe;GoogleTraffic
    by
    Code:
    RUN;C:\Program Files\RideRunner\Skins\DigitalFX 4.0\Scripts\GoogleTraffic\GoogleTraffic.exe;GoogleTraffic
    do you have a button with this line:
    Code:
    "load;rrtraffic.skin||RUN;$SKINPATH$\Scripts\GoogleTraffic\GoogleTraffic.exe;GoogleTraffic"
  8. #38
    Mar 2009
    I do not understand why this view
  9. #39
    May 2008
    Bordeaux, France
    Smile
    I think that is not our earth by may be Mars ?
    Do you have a gps on or off ? What zoom did you have defined . Settings are the default ?
  10. #40
    Mar 2010
    How to isntall this plugin
    I cant get this to work. I ve unzipped the files under
    C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite\Scrip ts\GoogleTraffic .
    and changed exectbl.ini at C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite to
    / MISC
    "CAMERA","LOAD;RRCam.skin||run;$skinpath$RRCam\RRC am.exe;RRCam.exe"
    "MyAppxx","load;rrtraffic.skin||RUN;$SKINPATH$\Scr ipts\GoogleTraffic\GoogleTraffic.exe;GoogleTraffic "
    I still dont see how I can add buttons. I looked throught the faq and I am not yet able to find out. As you guessed I am new to RR.
    Tx
  1. Less Virtual Earth modes available - 1.1.0.0
    By spaceskater in forum StreetDeck Bug Reports
    Last Post: 12-10-2007, 05:52 PM
