View Poll Results: Do you like this program
Voters
14. You may not vote on this poll
  • Yes
    13 92.86%
  • No
    1 7.14%
Page 5 of 11 FirstFirst 1234567891011 LastLast
Results 41 to 50 of 108
Thread: GoogleMaps & Microsoft Virtual Earth & Google Sky
  1. #41
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    Quote Originally Posted by krunkfoo View Post
    I cant get this to work. I ve unzipped the files under
    C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite\Scrip ts\GoogleTraffic .
    and changed exectbl.ini at C:\Program Files (x86)\RideRunner\Skins\Carwings_Dynamic_Lite to
    / MISC
    "CAMERA","LOAD;RRCam.skin||run;$skinpath$RRCam\RRC am.exe;RRCam.exe"
    "MyAppxx","load;rrtraffic.skin||RUN;$SKINPATH$\Scr ipts\GoogleTraffic\GoogleTraffic.exe;GoogleTraffic "
    I still dont see how I can add buttons. I looked throught the faq and I am not yet able to find out. As you guessed I am new to RR.
    I think that the good command is that:
    Code:
    "MyAppxx","load;rrtraffic.skin||RUN;$SKINPATH$Scripts\GoogleTraffic\GoogleTraffic.exe;GoogleTraffic"
    Tx
  2. #42
    May 2008
    Bordeaux, France
    Smile
    Always a little bug with these autoit script and RR.
    If Google Maps don't read your gps position, please change your 'regional options' to english.
    If somebody has a solution ?
    New scripts version for the new Carwings Lite, for GoogleTraffic , Virtual Earth and Google sky .
    The scripts now test if you have a wifi connexion !
    I have found some bug around the gps:
    -If no gps are found, the settings are well read.
    -If the gps is found, RR latitude and longitude are well used.
  3. #43
    May 2008
    Bordeaux, France
    Smile New update
    I think that i have found why the GPS coordinate are not well read in other language
    than the english or us language.
    Google don't accept the "," but only the "." .
    I have filtered the , and i think that all language can to be accepted !
    Try these new version and say me if it is ok for you .
    In french, i have no problem !
    Good use :-)
  4. #44
    Mar 2009
    for me not see the gps
    GoogleTraffic and VirtualEarth not connect to gps
    Google Earth is OK
    must look ride runner config ???
    thanks
  5. #45
    May 2008
    Bordeaux, France
    Cool
    Quote Originally Posted by achillealb View Post
    Google Earth is OK
    thanks
    Can you to try this version please ?
    The settings are modified:
    -Now you can to adapt the google traffic window to your skin by change the WindowsTOPoffset and WindowsBOToffset option (ex: replace 0 by +10 or -10).
    -The AllLanguage option change the ',' by '.' or not
    [Google Maps]
    WindowsName=GoogleTraffic
    WindowsTOPoffset=0
    WindowsBOToffset=0
    ForceSettings=no
    Lon=2.318459
    Lat=48.863064
    AllLanguage=yes
    ZoomLevel=12
    For the Carwings Lite sckin, i have these settings:
    [Google Maps]
    WindowsTOPoffset=-44
    WindowsBOToffset=+38
    ForceSettings=no
    Lon=2.318459
    Lat=48.863064
    AllLanguage=yes
    ZoomLevel=12
    Attached Files Attached Files
  6. #46
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    I get an autoit errir Line3244
    error: Variable used without being declared
  7. #47
    May 2008
    Bordeaux, France
    Smile
    with google traffic ?
    I have just tried and i have no problem with it.
  8. #48
    Nov 2006
    Just to add to the mix, I am building a Google Support package that will initially include Google Earth, Google Translate, Google Exchange and several others. It is a C# plug-in and will come with bare-bones skins simply to illustrate command and variable usage.
    The plug-in is built such that if the necessary input values are not with the command, it will present an internal GUI that will include an OSK-like keyboard control. I might also do this with Google widgits in a web-page that can simply be embedded in the users skin but don't know if I want ot make that change. It will also check if there is an Internet connection and if GPS is available.
    But, most importantly on the advice of an IPL attorney friend of mine, the output displayed will be the complete Google response web-page so as not to violate any copyrights by Google or it's partners. Extracting data and displaying it is, in his opinion, a copyright violation if complete attribution is not provided. His opinion is, in part, based on reading the Google terms of use.
    Additionally, parsing the response HTML, while fun, is a nightmare. The Google Translate and Exchange responses have changed twice in the last few weeks just enough to mess up the RegEx patterns I was using. This is an open invitation for constant update.
    So it may not be pretty in its raw form but it will provide the requested function.
    Regards,
    Jim
  9. #49
    May 2008
    Bordeaux, France
    Smile
    Quote Originally Posted by obrienj View Post
    Regards,
    Jim
    I am sorry but i understand very bad the English.
    If i understand well, you have a couplet project in C# around Google Earth ...
    Do you ask me to help you on this project ? I don't know the C# language , just a little autoit.
    Bu if i can help you it is with pleasure .
    Is it possible to try you full project?
  10. #50
    Nov 2006
    Your English is just fine so not to worry.
    If I may offer a little history for the project.
    I started this when I discovered that RREarth from Guino did not work with Google Earth 5.1xxx.
    As I worked on it I discovered several of the other functions that Google provides and found them of use in my Car PC which is actually in my RV and since I have full-time satellite Internet in the RV I decided to expand my project.
    To be honest, I am doing this primarily for my personal use and should anyone want it it would be available "as-is".
    So when I am finished you or anyone else can have it, source included to do with as you please.
    In fact, it might be nice if you could add Google Traffic, Google Sky, and others to it as I probably won't do that.
    It will be a few weeks before I have it ready for anyone.
    Regards,
    Jim
  1. Less Virtual Earth modes available - 1.1.0.0
    By spaceskater in forum StreetDeck Bug Reports
    Last Post: 12-10-2007, 05:52 PM
