Results 1 to 10 of 19
Thread: OnResume/OnSuspend Commands in ExecTbl.ini not working...
    Oct 2005
    I am not sure whats going on here but I am using the SerialSwitch plugin to get the DTRON and DTROFF commands (to turn on and off my amplifiers) unfortunately however when i stick the commands into OnSuspend/OnResume in the ExecTbl.ini they dont do anything.
    I have mapped dtroff/on to buttons in a skin and have confirmed that they work from there, so the commands themselves work, however Ride Runner just isn't sending them when hibernation is triggered/ends. Any ideas?
    MySQL Error
    Oct 2004
    u should look at debug.txt log, to see if RR even knows the system is going into hibernation
    like
    10/18/2009 1:06:21 AM: WM_POWERBROADCAST: wParam=PBT_APMSUSPEND
    10/18/2009 1:06:21 AM: PrepareForHibernate: (Start)
    10/18/2009 1:06:21 AM: Enter Exec: False, sirius.skin, "ONSUSPEND", False
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    Please note that the MSCOMM control from Micro$oft does not play well during Suspend/Resume...SerialSwitch uses this.
    For some it does and some it doesn't. Although it sounds like you have a differen't issue. Debug as Mitch suggested.
    ...JJG
    Oct 2005
    Here is what shows up in the debug from the initiation of hibernate:
    Code:
    25.10.2009 21:30:15: PrepareForHibernate: (Start)
    25.10.2009 21:30:15: Enter Exec: False, shutdown.skin, "ONSUSPEND", False
    25.10.2009 21:30:15: Que Exec: True, shutdown.skin, "ONSUSPEND", False
    25.10.2009 21:30:15: Executing: DTROFF
    25.10.2009 21:30:15: Command not executed: DTROFF
    25.10.2009 21:30:15: Que Exec: True, shutdown.skin, "ONCOMMANDINVALID", False
    25.10.2009 21:30:15: Executing: ONCOMMANDINVALID
    25.10.2009 21:30:15: Leave Exec: False, shutdown.skin, ONCOMMANDINVALID, False
    25.10.2009 21:30:15: PrepareForHibernate: (After radio power's)
    25.10.2009 21:30:15: PrepareForHibernate: Event/File Flush (end sub)
    25.10.2009 21:30:17: WM_POWERBROADCAST: wParam=0
    25.10.2009 21:30:17: WM_POWERBROADCAST: wParam=PBT_APMSUSPEND
    25.10.2009 21:31:06: Leave Exec: False, shutdown.skin, HIBERNATE, False
    25.10.2009 21:31:06: WM_POWERBROADCAST: wParam=PBT_APMRESUMEAUTOMATIC
    25.10.2009 21:31:06: WM_POWERBROADCAST: wParam=PBT_APMRESUMESUSPEND
    25.10.2009 21:31:06: ---------------------------->
    attached is the complete debug.txt and exectbl...
    Thanks in advance
    Attached Files Attached Files
    Oct 2005
    I don't know why the exectbl didn't attach hopefully this time it will
    Oct 2005
    Any ideas guys?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    This is a really easy fix. The reason its happening is that when you translate a cmd the translated cmd has to be BELOW the orig cmd calling the new one. You can either move your "DTROFF" line below the "ONxxx" events or you can change your "DRTXX" cmds to this:
    "ONSUSPEND","||DTROFF"
    By putting an empty cmd before it, forces RR to start back at the top when it tries to translate the cmd and b/c its starting at the top, it will find the new cmd....
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Oct 2005
    I'm going to try this when i get in the car, but that makes perfect sense. A little bit unintuitive but it makes sense.
    I'll report back.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Should work, is something that new skinners always run into and either figure it out by themselves or they search/ask.
    I have now also added extra notes to the main rr exectbl.ini file so that others don't have same hard time trying to figure out why their cmds are not working.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Oct 2005
    It works!... Kind of :/ The onsuspend command (dtroff) works just fine, but on resume it will not run dtron. I'm kind of confused.
  1. RR doesnt always see my HU commands
    By uhohrobbo in forum Road Runner
    Last Post: 06-09-2009, 06:37 AM
  2. pause with voice commands
    By vicky_obee in forum Road Runner
    Last Post: 05-04-2009, 08:06 PM
  3. Help to get the Radioshark plugin working
    By grahamjuk in forum RR Plugins
    Last Post: 10-01-2006, 02:21 PM
  4. Replies: 5
    Last Post: 06-20-2006, 12:20 PM
  5. Replies: 4
    Last Post: 05-01-2006, 11:48 AM
