Results 1 to 3 of 3
Thread: Make RR work on stock BMW monitor
    Newbie Silvano's Avatar
    Oct 2009
    Hello,
    i want to know is there some possibility to make RR start like CarX?
    I'll explane; when carx start and there is right ibus code(default BMW_TAPE=68043B460C1D
    BMW_TAPE_Alternative=54415045) carX display on monitor(i have to switch on cd or tape to have video signal)
    How i can do this also to RR? I downloaded ibusRR V2, do this program switch video signal?
    Thank you very much!
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    you will need to edit the IbusRR.ini file and add those commands to it's list
    ie
    ;Switch on tape
    [ID:TAPE_ON]
    MsgTemplate="68043B460C1D"
    TTR=2
    ;Switch Tape alternative
    [ID:TAPE_ALTERNATIVE]
    MsgTemplate="54415045" 'are you sure this is the right code?
    TTR=2
    You will then need to then either add a button to a skin like so
    b,x,y,w,h,"SENDMSG;iBusRR;TAPE_ON"
    or
    add to youe exectbl.ini
    "TAPEON","SENDMSG;iBusRR;TAPE_ON"
    and to the ONSKINSTART part of exectbl.ini
    "ONSKINSTART","TAPEON"
    Oct 2009
    Quote Originally Posted by Enforcer View Post
    ie
    ;Switch on tape
    [ID:TAPE_ON]
    TTR=2
    TTR=2
    or
    Thank you very much( also for responding on your own site)
    I think the code is right, also because the signal switch on correctly.
  1. Lsx Void 3.0
    By liquid_smoke in forum RR Skins No Longer Supported
    Last Post: 07-04-2011, 03:28 AM
  2. How do I get the Car2PC adapter to work in RR?
    By nasa in forum Road Runner
    Last Post: 08-14-2010, 01:30 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
  4. Replies: 96
    Last Post: 11-30-2006, 07:16 PM
  5. BMW original Monitor aux interface
    By Abel in forum Newbie
    Last Post: 06-22-2004, 03:26 PM
