Results 1 to 9 of 9
Thread: RideRunner Freezes when library is clicked
    Variable Bitrate ryuandwings's Avatar
    Nov 2003
    TN
    Guys, please help me.
    I just got all newest RR installed and when I click the library botton(to search for songs) in audio, RR freezes. Everything else seem to work.
    I have so far tried with winamp 2.91 and 5.13, and with 3 different skins.
    As soon as the library is clicked, CPU usage hikes to 90%+.
    Can anyone tell me what I am doing wrong?
    Thank you for the help.
    MySQL Error
    Oct 2004
    what skin... i know of no library button...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Quote Originally Posted by mitchjs View Post
    Browser button i think he means ,
    need to know what skin you are useing to help you
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Nov 2003
    TN
    Thanks for responding, guys.
    The main skin I am trying to use is "eLite Lite" and this is the skin with Library botton.
    I also tried with "Carwings_Dynamic_Lite", and this case the folder icon at the top bar in the MP3 player page.
    In "OMEGA", "View Album" icon.
    I just noticed something else, when I create a playlist in winamp then start RR, I can play songs normal. But if I open saved playlist within RR, it won't play and it keep skipping the songs till to the end of the playlist.
    I don't know these area realated issue, but happen in all 3 skins I tried.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    I dont't know about the other skins. Make sure you have those lines in the exectbl.ini file in the OMEGA FOLDER.
    /, View / Play Album Support
    "VIEWALBUM","RUNQ;$Skinpath$Scripts\AlbumPlayer.ex e|/B"
    "PLAYALBUM","RUNQ;$SkinPath$Scripts\AlbumPlayer.ex e"
    I've attached the exe if you don't have it. Extract to the Omega/Scripts folder and try again. It is working for me just fine.
    Attached Files Attached Files
    MySQL Error
    Oct 2004
    Quote Originally Posted by ryuandwings View Post
    thats because it(winamp) cant find the files.... (a path issue)
    are u really running the latest RideRunner?? 10/5?
    you should attach your rr.ini and a debug.txt, it would tell us alot about your setup
    (prob shouldnt help anyone till they post that)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    oh and stick with carwings lite, till u get all this working
    music path set right?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Open RR Config, and go to the music section, page 1.
    Check the top 2 lines:
    On the first line, ensure that you music path in RRConfig is correct.
    Then, on the second line, make sure the Playlist path is also set correctly.
    NOTE: The path to your playlists, has to be a folder that contains all of your playlists. You can not for instance have one in each artist folder.
    I personally have a Program ~..\Files\Ride Runner\Playlists\ folder where I store my playlists for use with RR.
    My Fiero Build Thread
    Nov 2003
    TN
    Thanks guys for he replys.
    Before I post debug.txt and rr.ini, I reviewed them myself. I found a bad line in rr.ini.
    [music]
    musicbrower=
    line in rr.ini was path to the folder nolonger existed and I guess that caused the RR to freeze when I try to browse for the music files.
    RR is running fine now. Thank you for your help.
    Ryu
  1. RideRunner / Winamp issues
    By TxAxZxZ in forum RR Bug Tracker
    Last Post: 03-28-2009, 04:48 PM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  3. Question about rebuilding library
    By hornyleprechaun in forum Centrafuse
    Last Post: 02-09-2007, 01:36 PM
  4. Replies: 19
    Last Post: 12-16-2006, 12:27 AM
  5. Library broken when importing 6200+ songs
    By robadob in forum Centrafuse
    Last Post: 09-29-2006, 06:18 PM
