Results 1 to 9 of 9
Thread: RR and Unicode
    Variable Bitrate ryuandwings's Avatar
    Nov 2003
    TN
    RR and Unicode
    I think I have proplem with unicode in RR.
    Basically some fonts are not correctlly displaying in RR.
    Please see attached images.
    First image is the folder name as it appears in Windows and it is displayed correctly.
    Second image is from browse page in RR and the folder name is not correct. There are many other instances.
    Becouse it is not correct, I can not select the folder to do anything.
    As I understand, I don't have to set "international" and "locale" in setting anymore, at least the option is not part of the configuration.
    I have set the Unicode to Japanese in control panel, regioal setting.
    Can someone tell me what I am doing wrong?
    Ryu
    MySQL Error
    Oct 2004
    we dont even know what version of RR you're running...
    really need to post some info
    alot of work has been done on unicode
    what version of RR
    if winamp as player what version
    things like that
    Guino, prob knows what better questions need to be asked
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    MySQL Error
    Oct 2004
    from another POST... i see u menu using winamp 5.13
    winamp that OLD doesnt support unicode
    i would make sure you install the NEWEST winamp
    also... you should have RideRunner 10/5/2009!
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Nov 2003
    TN
    Mitchjs
    I updated winamp to 5.56. Still the same thing...
    RR should be the latest, it says 10/06/09.
    What other information should I give you?
    Thank you for your help.
    Ryu
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    can you please try different skins ? this could easily be a font issue, meaning the font used in that specific skin doesn't have the characters you're trying to display. I would also suggest trying to change the font name in the skin directly/manually to use a font that you KNOW works with your specific text.
    Ride Runner RR's Myspace
    Nov 2003
    TN
    guino,
    I changed the font in each skin file with two fonts that are standard Japanese Windows fonts and same result.
    Also tried with Carwings and Omega skins and same result.
    Are there anything else I can try?
    Ryu
    Nov 2003
    TN
    guino,
    After playing around for more, I noticed a pattern.
    When I select a folder and add entire folder contents in "browse" page, then all songs are displyed correctly in Audio Player Play list.
    But if I try to select same songs in the same folder individually, then I can not select the song.
    It seems like the audio browse page is causing this problem.
    I hope this make sense.
    Ryu
    MySQL Error
    Oct 2004
    i did a bunch of work on unicode...
    i found and fixed some things
    i need a tester
    pm me
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    i think i got this nailed...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. RR 09-22-2009 Release
    By mitchjs in forum Road Runner
    Last Post: 10-01-2009, 07:50 PM
  2. RR 08-01-2009 Release (Updated: 8/21)
    Last Post: 09-07-2009, 08:44 AM
  3. Unicode - My findings and maybe a bug?
    By RS200Z in forum Road Runner
    Last Post: 06-01-2008, 12:21 PM
  4. RR 09-02-2007 ... Way Overdue update ..
    By guino in forum Road Runner
    Last Post: 02-05-2008, 08:34 PM
  5. Replies: 0
    Last Post: 11-04-2005, 06:20 AM
