Page 1 of 8 12345678 LastLast
Results 1 to 10 of 72
Thread: RR 11/01/2009 Release
    MySQL Error
    Oct 2004
    *** Available now from here ****
    Alot of work in this build for UNICODE, and there is some FYI you need to read about UNICODE and NWU
    http://www.mp3car.com/vbulletin/rr-f...ml#post1353843
    Thanks to Blue & Guino (we spent a ton of hours just on unicode)
    Some Highlights:
    "SHOWFLASH", lets you hide and show flash objects on the fly
    "PLAYITEM", to play any item in the playlist directly
    REWRITE of MPC Video module, much improved!
    ID3v2.4 support
    Flac Tag support
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = bug fix
    ^ = Note
    11/6/09
    ! Rewrote MPC Player module, now uses socket commands to play, for much improved playback
    11/5/09
    * Improved Folder Detection for NWU folders
    * Improved "SELECT" to be aware of playlists mixed with files
    + Added a "HIDE" option to the flash skin definition
    + Added "SHOWFLASH" skin command for use with the "HIDE" option above
    11/3/09
    # Unicode ID3v2.x tag fixes, removed lingering VB6 code, replaced with Win32API
    # Unicode folder names supported
    + ID3v2.4 support
    + Flac Tag support
    10/30/09
    + Mp3Car.com HD Radio Tuner support
    # Skin definition command "IND" now will process all indicators on skin
    10/26/09
    + ReloadKeytbl cmd to reload the keytbl.ini file w/o restarting RR
    10/21/09
    + Allow for plugins to return replacement "CODE" (processcode=3) for ONxxxx Events (processcode=1 also supported)
    + M4a file extension added for supported foobar extension
    10/17/09
    + SKIN COMMAND: "PLAYITEM" to play any item in the playlist directly
      Example:   "PLAYITEM;1" (Plays first item in the list)
    # Fixed WMP Player Visualization Position Issue
    10/11/09
    # Minor fix to launch skin so it does not display images outside of launch folder
    10/6/09
    + SKIN LABELS: GPSSPDN and GPSALTN (same as GPSSPD/GPSALT without units shown)
    10/5/09
    # SETLABELCODEID command fixed, last worked in the 8/1/09 release
    # Path bug for plugin data path
    # Foobar2000 player, a few different issues
    # tagcache.ini not saving on exit
    + Added ONRBUTTON, ONMBUTTON events (Right/Middle Mouse Button Clicks)
    # SkinEditor bugs fixed, see skineditor history.txt
    * SkinTool updated v2.0, see skintool history.txt
    * RRconfig, Added wintvpath, closeplayeronexit settings
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Aug 2004
    Germany
    Thanks alot .
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Thanks a lot for all the hard work!
    Unicode 2.4? I don't even know what that means. Just a question, would that work with Winamp 5.56 (lots of options for installation, maybe one work?) I mean, winamp 5.13 does not support unicode, right? So something higher than that must be installed for it to work, or use another player (but most skins don't use WMP's (very fast) database to search and organize tracks, etc.).
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    fastmode=0|1|2
    Use faster screen loadings -- default OFF (0)
    On faster machines it is suggested that you leave it =0.
    By default, my setting fasmode is -1 .
    If i change by 0 (for test if rr is faster) , RR say me that the Carwings skin is not a valid skin !
    carwings uses .pngs, fastmode MUST be -1, which enabled GDI+
    -1 is the right setting...
    if you cant do GDI+ (slow old machine) prob time for new machine
    May 2008
    Bordeaux, France
    The skineditor is the 0.76c version not the last 0.76d ?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Ya, looks like that might have slipped by...
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    MySQL Error
    Oct 2004
    Quote Originally Posted by RipplingHurst View Post
    not "unicode 2.4"
    id3v2.4 tags... google
    they new, windows 7 doesnt even support them
    i would stick with id3v2.3
    yes, 5.13 does NOT support unicode
    i would use the newest winamp, cant see any reason not too
    also, if you use another player, like WMP, tags come 100% from RR code, not from player
    WMP and other players, where RR is concerned is for PLAYING not any music organizing
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by konrad View Post
    thanks alot .
    +1
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Dec 2007
    Danville, CA
    Quote Originally Posted by mitchjs View Post
    not "unicode 2.4"
    Unicode 2.4...LOL...what was I thinking?
    I don't understand exactly what some skins do with winamp then. Maybe they just use winamp database (searching, playlist, etc) and you can still use WMP player? I've tried 5.56 once in Windows 7, I think I had some problems though, but I'll try again.
    But I think that's a skin related issue.
    I got your point though, I *think*. For what your saying is, it doesn't matter whatever else the skins use the winamp for, when it comes to PLAY the file, RR let's you pick whatever you want, now to SELECT what file to play next, etc. if the skin uses winamp database or whatever, it has no bearing on RR using WMP or whatever else you've set: the skin does not even need to "know" about it, right? (does that make sense? )
    MySQL Error
    Oct 2004
    i dont know of any skin, that uses winamp db, im not even aware of winamp having a db
    iTUNES has a database
    i been using win7 since beta 2, and NEVER had any issues with WINAMP
    keep in mind OLD winamps, were not UAC compliant, ie they tried to write in thier program files directory... but thats been long since fixed in winamp
    i would hope that skins dont depend on any one player, but it could happen...
    I use WMP sometimes when testing, cause its just simple, and it works, and plays all my music... i do winamp too, just becuase 90% of RR users do, so i want to make sure its working correctly
    RR has its own internal playlist management
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Why do people think RR is hard to setup?
    By 2k1Toaster in forum Software & Software Development
    Last Post: 05-18-2008, 01:38 AM
  2. Replies: 70
    Last Post: 10-15-2007, 06:21 PM
  3. Radio control with iBus ???
    By jeep642 in forum Car Audio
    Last Post: 10-02-2007, 12:51 PM
  4. Songs and Folders not showing up in new RR Release
    By jwlionking in forum Road Runner
    Last Post: 09-06-2007, 03:55 PM
  5. RR 05-28-05.. Early Release..
    By guino in forum Road Runner
    Last Post: 06-04-2005, 09:36 PM
