Results 1 to 10 of 10
Thread: how to put rrrufsion momentary button in keyTBL.ini
    Jan 2007
    im trying to map a rrfusion command into the keyTBL.ini but all variations i have tried so far wont work.
    toggle buttons work fine with this command:
    key#,"DIGITALOUT0;TOGGLE",
    however momentary buttons wont work
    key# ,"DIGITALOUT0;RELEASE &DIGITALOUT2;HOLD& "
    i hope someone can help me out with the right syntax, format here...
    thx!
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by sgtpepperaut View Post
    thx!
    thats not going to work. i dont believe any HOLD function can be assigned to a key. Its an RR limitation... because holding down a key actually fires the key over and over again instead of a hold/release that RR needs to see.
    Live mp3Car Facebook Chat
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    that's just how the keyboard works anywhere -- pressing and holding a key will always repeat the same key. The recommendation is to assign a key to start and another to stop, so you'd do a simple press on the start key, then instead of holding it till the time to release it, you'd only press the other key to end it -- which is what you may be doing with the toggle thing (I don't know). Outside of that, a plugin could be made to monitor the press-and-hold of keys and generate events based on that, but it may not be simple to detect a key state (up/down) if you'll be sending other keys in between the press-and-hold (again don't know if that's needed).
    Ride Runner RR's Myspace
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I have something I thru together, but I cant check at work(ba$tards) so I'll check when I get home and post a solution if find its works as coded...
    Stay Tuned....
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Jan 2007
    sweet.... and thx.
    i can now control basic car functions from my phone with nokia wireless presenter which maps my phone keys to "simulate" keystrokes on the remote machine.
    so the toggles, ie lights ignition etc. work fine. However Windows up Down for example would need to be momentary. There is a command that will keep the rrfusion relay on for a given time period but the problem here is that its +-1.5s which is not sufficient for window motors...
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Here it is...
    Put both files anywhere, both have to be in same dir. Program will only send cmds when:
    #1 Program is running (If running old RoadRunner, change the name in the settings
    #2 Program is in focus
    If both are met when key is pressed will fire the first cmd, second when released. The two single cmds are seperated by a ";"m, just use the exectbl to translate to what ever you want done.
    This will Accept: Key, Ctrl+key, Alt+key, Ctrl+Alt+key now!
    Additional notes in the ini file.
    Hope it works for you...
    Attached Files Attached Files
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Jan 2007
    ok so correct syntax would be:
    2103="DIGITALOUT13;RELEASE";"DIGITALOUT13;HOLD"
    im asking because there is a ";" in the commands...
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    No, you can only use simple cmds, then use those to translate in the exectbl.
    so...
    2103 = Ctlr + Numberpad 7
    In app ini:
    2103=RRFB_0_ON;RRFB_0_OFF
    in Exectbl
    "RRFB_0_ON","BYIND;DIGITALOUT0STATUS;DIGITALOUT0;T OGGLE<<"
    "RRFB_0_OFF","BYIND;DIGITALOUT0STATUS;<<DIGITALOUT 0;TOGGLE"
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Ok, I've updated #6 post with newer version...
    Added support for ctrl & alt key combo's
    Reduced Mem usage while running ~800K!
    There is an example in the ini file using the "d" key
    I also updated the above post to use your orig example from first post.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I love, and i see what i can to with !!!!
  1. Replies: 5
    Last Post: 03-06-2009, 05:15 PM
  2. Some thoughts on front end UI
    By NSFW in forum Software & Software Development
    Last Post: 09-10-2008, 07:47 PM
  3. Change Log
    By iamgnat in forum CarFrontEnd
    Last Post: 03-19-2008, 11:33 PM
  4. LSX (VOID) released
    By liquid_smoke in forum RR Skins No Longer Supported
    Last Post: 03-01-2007, 11:43 PM
  5. Button request: Minimize
    By DaveB in forum Mobile Impact
    Last Post: 01-04-2007, 09:35 PM
