Results 1 to 10 of 11
Thread: skin help, append playlist to current playlist
    Aug 2004
    Germany
    I want to be able to add a selected playlist to the current library (as !LOADLIST) does, but without interrupting the current playing song. Is that possible ?
    I found ADDTOLIST (from skin commands: Example: "ADDTOLIST;C:\Test.m3u"), but this command doesn't work for me. Here are the debug lines:
    Code:
    16.11.2009 17:31:16: Que Exec: Wahr, audio_browser.skin, "ADDTOLIST;C:\Users\K W\Desktop\rrMediaBase\results.m3u", Falsch
    16.11.2009 17:31:16: Executing: ADDTOLIST;C:\Users\K W\Desktop\rrMediaBase\results.m3u
    Nothing happens though. When I replace ADDTOLIST with "!LOADLIST" it works, so the path seems to be correct. Bug ?
    Also, can I prevent that RideRunner starts playing after loading a playlist ? Or is that a WinAMP setting I can't find ?
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by Konrad View Post
    Use ADD1.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Aug 2004
    Germany
    Nope, doesn't work. I tried "ADD1;results.m3u", then an entry "results.m3u" appears in the playlist, not the songs.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    This does work, I use it in my media plugin. Try putting the full path to the to the file
    ADD1;C:\Users\K W\Desktop\rrMediaBase\results.m3u
    Only way to prevent it is to append a "||STOP" to the end of your cmd code line
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Aug 2006
    Sun Diego
    If the current screen is using a DL that lists your playlists, you don't need the path.
    Aug 2004
    Germany
    Found the bug. RideRunner doesn't seem to like quotes. That wasn't the first time I ran into problems with this. Thanks guys.
    Code in AutoIt:
    Code:
    $result='"D:\Programmierung\AutoIt\MediaBase\results.m3u"'
    $rr.execute("ADD1;"&$result)
    This it what RideRunner does with it:
    Code:
    17.11.2009 11:24:16: Que Exec: Wahr, audio_player.skin, "ADD1;"D:\Programmierung\AutoIt\MediaBase\results.m3u"", Falsch
    17.11.2009 11:24:16: Executing: ADD1;"D:\Programmierung\AutoIt\MediaBase\results.m3u"
    Looking at the playlist in rr there's an entry called results" (just one quote)
    Lookint at the playlist win winamp the entry is called results. When I click on "View File Info" it says "D:\Programmierung\AutoIt\MediaBase\results.m3 u"
    MySQL Error
    Oct 2004
    looks like u just go too many qoutes
    at least it looks that way
    "add1;D:\Programmierung\AutoIt\MediaBase\results.m 3u"
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Aug 2004
    Germany
    This line:
    Code:
    results in the variable to contain
    Code:
    This variable is sent to RideRunner. This is what RideRunner makes out of it:
    Code:
    I guess RR isn't meant to interpret quotes like that, is it ?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The extra quotes are not meant to be there by definition of the command. With exception of the RUN command (in some specific cases) no RR commands should have quotes on paths as RR only interprets the commands as defined in skin commands.txt -- if you do anything different, it may not work OR may work differently by coincidence -- anything that is not done as described in skin commands.txt is not guaranteed to work in future releases.
    Ride Runner RR's Myspace
    MySQL Error
    Oct 2004
    konrad... id think it just be
    $result='D:\Programmierung\AutoIt\MediaBase\result s.m3u'
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Chuck's Skins lots of pics Update 7-16-07
    By Chuck in forum RR Released Skins
    Last Post: 11-10-2011, 08:22 PM
  2. Replies: 0
    Last Post: 09-24-2009, 02:28 PM
  3. How To: Get your new skin out to the masses.
    By monkeyracer in forum RR FAQ
    Last Post: 07-19-2008, 08:59 AM
  4. Enlarge Current Track in Playlist
    By dbassix in forum RR Skins
    Last Post: 11-06-2005, 03:32 PM
  5. Replies: 3
    Last Post: 04-19-2005, 11:29 AM
