Results 1 to 4 of 4
Thread: create label from existing label with math opertions...
    Jan 2007
    is there a way that i can create a new RR label by using an an existing one and applying math operations to it? (continuously...or in short intervals)
    i measure my cars battery voltage with the FusionBrain. i had to use a voltage divider which "divides" the voltage to about 0.25 times the original value. So now in order to display the actual voltage i would need to multiply the label/variabel by 4.....
    or lets say i want to display the speed that i am going over 50mph....
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Try RRExtended plugin, I think that can do that.
    or maybe set a variable from a label and see if you can do maths on that
    Jan 2007
    well i found some info in the orig documentation but i could not get it to work
    SETVARBYCODE;MYNEWVOLTAGE;analog0raw
    EVAL;RESULT;$analog0raw$*4
    Aug 2004
    Germany
    You got it wrong. Can't test at the moment, but should be like this
    FYI: SETVARBYCODE;<target variable>;<value>
    Code:
    EVAL;RESULT;$MYNEWVOLTAGE$*4
    1. copy the value from analog0raw to variable MYNEWVOLTAGE
    2. multiply MYNEWVOLTAGE by 4
    Now you just have to display the new variable MYNEWVOLTAGE (instead of analog0raw) in the skin you're using.
    The value of MYNEWVOLTAGE doesn't update automatically, you have to work with a timer.
  1. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
