Results 1 to 5 of 5
Thread: Windows crash when start RR, how to debug?
    Dec 2008
    Sometimes when start the RR, windows XP crash and restart again and again. This happen recently after I configed the winamp with ASIO output. The winamp version is 5.13, my new sound card is EMU USB 0404 and the out_asio.dll is from here http://otachan.com/
    After the windows restart, it report that there is a dump. I suspect that it was caused by the asio plugin, but how to prove it? Anybody can read the dump? any suggestion to a stable asio plugin for winamp?
    MySQL Error
    Oct 2004
    dont use asio for a a few times
    any real reason using ASIO, NO NEED FOR low latency audio in a carpc, its pointless
    is there a normal wdm driver?
    update winamp to something modern (5.13 is very old)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    In general, no "Application" causes windows to crash -- sure applications may crash but that will only close the application. Only DRIVERS can make windows crash - so definitely some DRIVER that RR/Winamp is using (audio/graphics/etc) is causing windows to crash. I would suggest following mitch's suggestion: Try a different audio DRIVER and/or a newer Winamp.
    Ride Runner RR's Myspace
    Dec 2008
    Yes, low latency is not necessary for me. I want to use the SPDIF output of the EMU0404. Have not found a driver other than ASIO to support it.
    Found a post http://www.audioasylum.com/forums/pc...s/2/28294.html
    The guy said " In order to use S/PDIF with the E-MU 0404 USB, ASIO must be used in the playback software"
    MySQL Error
    Oct 2004
    just using SPDIF? are you using the analog also?
    if just spdif... dump that thing, and get a simple usb to spdif
    one based on a TI PCM2xxx
    that box is way overkill
    and you're stuck with custom drivers
    on ebay, tons of TI PCM options cheap, and really nice stuff
    seach "usb spdif"
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-09-2012, 10:46 PM
  2. HELP!! RR not working with Windows 7
    By afterdigital in forum Road Runner
    Last Post: 01-15-2009, 08:45 AM
  3. Replies: 4
    Last Post: 10-01-2006, 01:01 PM
  4. RR Crash: MM not found or not listening
    By wizz in forum RR Bug Tracker
    Last Post: 04-11-2005, 06:31 PM
