Results 1 to 10 of 10
Thread: Issue after upgrading
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    Hi folks,
    This evening I upgraded to the Nov09 release .. from the Oct 09 release.
    One thing I cannot figure out is on my directory list in background browser. I have this code ..
    /, Directory Format
    SD,00,00,30,30,"$BACKGROUNDPATH$","*.jpg",0
    /, iList Support
    IL,DL,transparent.bmp,sel.bmp,end.bmp,2,50,60
    but no matter what I do, it displays a windows media player icon on the left of the DL.
    In my logos screen I have ..
    /, Directory Format
    SD,00,00,30,30,"$SKINPATH$LOGOS","*.png",0,,,,,,,
    /, iList Support
    and it does not display any icons on the left of the list ... nor does it display icons on the audio browser screen ... ONLY the background browser screen.
    Also I have the "show icons" check box turned off in RR.ini ..
    Any ideas please ?
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You're specifiying icons of 30x30 to be displayed (SD definition). In any case, if you disable the show icons option, then it should not matter.
    Please open RR.INI (DIRECTLY) and verify you have showicons=false -- and that you only have 1 showicons= line in the whole file. Please note that not having a showicons= line is the same as having showicons=true (which is the default).
    Also note that showicons is a global option -- having it OFF will disable icons on ALL lists -- not just the folder list.
    Ride Runner RR's Myspace
    Jul 2007
    Ireland
    Yes in RR.ini there is only one showicons andit is set to false.
    I did try setting the icon size to 00,00 in the SD but that did not good either.
    One other thing I've noticed is that there are two icons being added to my skin folder - these are called media.gif and folder.gif - i've no idea where these are coming from. Everytime I delete these they get recreated as soon as I load the skin again.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Basically, iLists should work just like standard lists, if icons are supposed to show, they should show even if using the internal (default) icons -- those are the ones you're seeing being created in the skin folder. Note that previous versions did not have enough support to use the internal icons (as it should), so this could have caused icons to not show (when they actually should show).
    I have your skin Teknik 4 installed here, if that's where you're having the issue, please post the updated .skin files (and images if changed) for those two screens and I'll give it a try to see.
    EDIT: Just tried teknik4 and there seems something wrong as icons are showing (only in the two screens you made) even with showicons=false. I'll take a look at it.
    Jul 2007
    Ireland
    Hi there,
    here are three skins ... audio browser, backgrounds and logo's. Sorry about this guino but this is happening on both the backgrounds screen and the logo's screen.
    I've also included the rr.ini file that is on the system.
    Attached Files Attached Files
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I figured out the issue using the standard teknik4 skin (already installed here), the problem was related to using ilists on custom screens with dirlists. I have fixed it for the 12/1 release.
    EDIT: for those using showicons=true, you may want to provide a "default" icon used for the background/logo screens (i.e. an "image icon")
    Jul 2007
    Ireland
    so is there anything I can do with the Nov 09 version to correct the issue, or do we need to wait for the next release ?
    MySQL Error
    Oct 2004
    ah, december is but a day away... u prob can wait
    heheheh
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Jul 2007
    Ireland
    ah sure I suppose you're right mitch ... man where has november gone to ???
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I don't know...but look...ah too late, its gone now...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  1. DigitalFX 4.0
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-27-2014, 05:48 PM
  2. My RR/DFX 4.0 100% CPU usage issue
    By Minoritydan in forum RR Bug Tracker
    Last Post: 12-23-2008, 01:40 PM
  3. No audio after resume from hibernate issue - almost fixed - Help me finish?
    By Trin in forum Software & Software Development
    Last Post: 07-26-2008, 08:35 AM
  4. Another Lilliput issue, Maybe
    By djmickyg in forum LCD/Display
    Last Post: 05-04-2008, 06:29 AM
  5. M4-ATX Power On Issue
    By PacketSniffer in forum Power Supplies
    Last Post: 04-24-2008, 11:00 PM
