Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 76
Thread: RR 12/01/09 Release
  1. #31
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by bratnetwork View Post
    I can't explain how, but in the previous version they displayed properly in my skin
    I'll PM Guino with some files
    Should be easily fixed once I see the files
    Ride Runner RR's Myspace
  2. #32
    guino's Avatar
    Nov 2004
    Toronto, Canada
    With this new update of RR I am having an issue with the way that ID tags are displayed in RR from FLAC files. MP3 files are fine still. I am use Foobar2000 as my player and I didn't change anything with Foobar nor did I change anything is rr.ini. I just updated to this new version of RR and ran the registration tool. Here is a pic of my audio_browser screen with the error.
    I just looked at your files... there's a big "NO NO" going on here... your flac files have ID3 TAGS!! (ID3 tags should only be used with MP3 files). However, your files also have the correct vorbis comment tags which are supposed to be used on FLAC files. RR was getting confused because of some of the data in the ID3 tag and was reading the info from the wrong place. This should be fixed for next release.
  3. #33
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by guino View Post
    Have you tried to run Skintool as administrator ? (it may work)
    Quote Originally Posted by pierrotm777 View Post
    No . I can test that
    This shouldn't be needed, run as admin. as the newer versions do not write to it's folder(in prog's)
    Try deleting the "skintool" file in its folder if it's there. I have even a newer version (2.1.1) that I'll put in the skintool thread that yet.. adds more help
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #34
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Will also mention that I too have seen that weird first line of anti-matter that in a ilist when it loaded.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #35
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I need to jump on this.. is it happening with all ilists, just a specific type (CL/DL etc) or maybe just the ones with/without icons ? I need a clue on where to look at this as I haven't seen it happen.
  6. #36
    Jun 2007
    St. Louis
    I haven't seen the screen corruption, but my ilists are now VERY choppy. No hard drive activity when it happens and I'll double check, but CPU utilization isn't high either.
    Running a 2.4Ghz Core2 based Celeron w/2GB ram, SSD, Windows 7. Seems to do it in XP as well.
  7. #37
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    What is the proper format for tags in a FLAC file? I will look if my ripping software has that option.
  8. #38
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    I have "anti-matter" only in CL without icons, no probs with PL or DL.
  9. #39
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The tags for FLAC files are the same exact format as in OGG files -- "Vorbis Comment" type. Your files also had that along with the ID3 tags -- hopefully you should be able to disable the ID3 tags for FLAC files only.
  10. #40
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I have update the skintool here, last post...
    Thread
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Replies: 70
    Last Post: 10-15-2007, 05:21 PM
  2. Radio control with iBus ???
    By jeep642 in forum Car Audio
    Last Post: 10-02-2007, 11:51 AM
  3. Songs and Folders not showing up in new RR Release
    By jwlionking in forum Road Runner
    Last Post: 09-06-2007, 02:55 PM
  4. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
  5. RR 05-28-05.. Early Release..
    By guino in forum Road Runner
    Last Post: 06-04-2005, 08:36 PM
