Results 1 to 10 of 14
Thread: registration problem ?????
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    I tried to register my copy of RR using the provided reg tool. After accepting the terms I was presented with the email and hard drive screen. How can I find my hard drive serial number, it is not displayed by the tool ?
    The road is long but we are getting there.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    what os?
    (hopefully not win9x)
    what kind of hard drive is the primary drive?
    anything special? (raid)
    Ride Runner RR's Myspace
    Dec 2003
    Greece
    The OS is win xp pro sp3 Greek
    Disk Drive is SATA western-digital 160gb. No raid or anything special
    MySQL Error
    Oct 2004
    check the "Windows Management Instrumentation" service
    it should be running...
    is this OS Nlited?
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Dec 2003
    Greece
    How do you go about doing that ?
    is this OS Nlited?
    No it is not Nlited. Actually it is a fresh 2 month old install with all the goodies
    MySQL Error
    Oct 2004
    its in services... right click my computer, manage, services
    be really odd if your hard drive didnt have a serial number
    there is also this (wmi diag), but i got a hunch, wmi is fine
    http://www.microsoft.com/downloads/d...displayLang=en
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Dec 2003
    Greece
    I found a tool on the net that shows you the HD serial number
    the number that it shows is 8817-5421. Do you think that this is correct?
    MySQL Error
    Oct 2004
    no, that looks like a volume serial number
    and for this whole thing to work, WMI needs to return a valid mfg serial number
    if that doesnt happen, you cant use the registration system
    and wmi might be working...
    try this app... does it show valid data...
    neat app too
    HERE is what my cpu looks like
    Attached Files Attached Files
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Please try this tool as well and tell us what it shows for serial:
    Dec 2003
    Greece
    mitchjs, I tried your app and it shows valid data on all components.
    I tried guinos tool and I got a serial number WD-WCANM2463823. I sent this in along with my email and got back the registration code which a copied into rr.ini.
    I then set the date ahead 1 year and tested RR. Unfortunately the warning screen came up.
    Edit.
    The code the I got had the form
    regcode=........
    regmail=.........
    At first I thought that I was supposed to copy also the line regmail=... to my rr.ini
    After removing the regmail=... entry from my .ini file everything is OK.
    Thank you both for your time an patience
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-31-2006, 12:09 AM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 08:41 PM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 11:38 AM
