Results 1 to 10 of 10
Thread: [slvd] CPU/memory/temps not displaying
    Variable Bitrate Wayne613's Avatar
    Apr 2009
    Delaware
    Well...They display, just not correctly. Temps show as 32 degrees all around, CPU as -1 constantly, and the physical memory as 1.8gigs out of 1.2. As you might imagine, having 4gigs of physical, that might be amiss. =)
    I thought it might have just been something I did, didn't do, or something specific to my motherboard, but it's doing the same thing on this laptop with windows 7 64-bit (same OS on both). Skin doesn't matter, I've tried a couple now. But default is DFX4.
    I'd just straight post this to bugs section, but someone else stated they didn't have an issue in 64bit win7, so I'm probably just missing some directx or activex plugin. Can someone tell me how it's getting the info? I probably just need to get some ocx that isn't installed by default, but I have no true idea how it's getting the info.
    Thanks!
    Jul 2006
    Are you running speedfan? Speedfan has to be running, and the labels set up correctly for it to work right.
    Apr 2009
    Delaware
    Quote Originally Posted by barnyard View Post
    I suspected that for the temps perhaps, but the memory and CPU in use? Don't recall installing that for my XP 32bit install where everything worked.
    Just installed speedfan on the laptop here, nothing changed.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The Temperature Displays require either SpeedFan, MBM or a HARDWARE (32F = 0C which is the default value). The CPU and memory don't require any other software, however I personally haven't tried it on Win7 64bit -- which may be an issue (?). CPU may be a permission issue, while the memory may be a limitation with the APIs we use -- we'd probably need to upgrade somehow.
    Are you running RR as the administrator ? (just want to be sure)
    Ride Runner RR's Myspace
    MySQL Error
    Oct 2004
    fixed for vista/windows 7 x86 and x64
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Apr 2009
    Delaware
    Quote Originally Posted by guino View Post
    I have UAC set to the lowest on it, which is essentially turning it off, correct? But I tried here and the car running it as such, no change. CPU in use/load and Memory are still wrong.
    The OS version, main drive size, in use values for it, and the CPU speed are correct.
    Temps are unchanged by installing speedfan, which does display them running by itself. I assume that's just a case of the labels being wrong.
    MySQL Error
    Oct 2004
    wayne613,
    yes, you have uac off
    its fixed for next release of RR (CPU useage that is)
    it was using OLD APIs, i updated the code to if OS is Vista or Win7
    it will use the new API
    speedfan 4.40 is working fine
    use skintool, and explore ur labels
    SFT0
    SFT1
    SFF0
    SFF1
    like that... i noticed for volts every other had data
    SFV0
    SFV2
    SFV4
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Apr 2009
    Delaware
    Quote Originally Posted by mitchjs View Post
    wayne613,
    SFT0
    SFT1
    SFF0
    SFF1
    SFV0
    SFV2
    SFV4
    Yeah, this took some research as I've never actually altered or really messed with much of any of these skins, settings and such before. I got it sussed for this part though.
    DFX uses the MBM5 label (motherboard monitor) in the task_man skin, so just needed to change it to the speedfan one and alter the appropriate Tvalue for the temperature.
    Making me learn stuff, bastids!
    Apr 2009
    Delaware
    I did a quick search, and I think I know the answer. But just for s**ts and giggles...
    Is there a repository available to get the current dev version? I'm going with no, but never hurts to ask, I assume it's only available to the rest of us through the current NISU cart down-loadable version, correct? It is just once per month barring a major bug-fix as well, right?
    2008 Ford Mustang GT/CS CARPC(99%)
    Software: Ride/Road-Runner, Digital FX skin 5.x, iGuidance 2011, GPSgate on Win7 64bit
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Wayne613 View Post
    There's a SVN repository, but it has controlled access. We're actually trying to get things OUT of the core code and put it into plugins, so contributions are best made in the form of plugins. In regards to bugs: when a buf is reported/fixed, we generally can send out a beta version with that bug fixed before the next release -- at request.
  1. Not displaying locked satellites
    By telmel in forum Centrafuse
    Last Post: 07-15-2007, 05:45 PM
  2. Chinese characters not displaying properly
    By nobb in forum CF Bug Reports
    Last Post: 05-03-2007, 06:14 PM
  3. Displaying "Artist - Album - Track - Title"
    By tbird2340 in forum Road Runner
    Last Post: 02-01-2006, 01:04 PM
  4. scale on map not displaying correctly
    By tolisn in forum FreeDrive
    Last Post: 07-28-2005, 06:33 AM
  5. Xenarc only displaying 2/3'rds of screen when in Windows.
    By tbird2340 in forum General Hardware Discussion
    Last Post: 12-15-2004, 04:56 PM
