Results 1 to 9 of 9
Thread: lost the three dots ( ... )
    Constant Bitrate popi79's Avatar
    Sep 2006
    For some reason I lost the three dots located at the root of music library where you can choose all artist in the library.
    It used to be:
    -Albums-
    -Artist-
    -Genres-
    the dots under genres is the one I used to click to load the whole library to play list.
    Any ideas?
    "Most of the users you'll see in this site are still learning specially me"
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    it's probably TWO ( .. ) dots -- not three. Uncheck the option to hide dots in RRConfig, or make sure hidedots=false in RR.INI.
    Ride Runner RR's Myspace
    Sep 2006
    Ok..
    Ok, I checked the two options that you suggested and nothing...
    The remedy.... Well I created a new button in the music browser skin with the command "SELECT+" now I click the first artist in the list and the "SELECT+" command and It adds all the artists to the play list.
    Now I was wondering... can one button be set to send more than one command, like for example at the push of that proposed button be like load all artist to play list and play command at the same time, like a random play all like button in a regular portable media player like the creative zen. just one quick way to load everything and play...
    Thakns guino...
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You may want to check that you have the setting pathlimit=false in RR.INI , and set it if you don't.
    You can have the same button execute multiple commands separating them with || like "SELECT+||EXIT" -- this is all in skin commands.txt.
    Sep 2006
    Bingo...
    Yes I checked the rr.ini and was not present...
    added the string (pathlimit=false) under the music block and BOOM... It worked.
    Thanks Guino....
    Sep 2006
    Report... to Guino
    after adding the pathlimit=false command in the rr.ini every time I go to the rr configuration tool it erases the command.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by popi79 View Post
    try adding it to the "extras" section on RRConfig.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by guino View Post
    When a setting is not a RR recognized setting, the config re-adds the same setting to the bottom of the ini uner "Extras"
    [Edit]
    There was a bug in the config that I just found reguarding this setting, now fixed.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Sep 2006
    Still the same...
    Still the same issue with the pathlimit=false in the extra section.
    Well I'll use the new button that I created to load all files to play list.
    note: I'm using 1022 version of RR.
    Thanks anyways...
  1. Completely lost when it comes to power supplies
    By Bilbo99 in forum How to Power a Laptop
    Last Post: 12-13-2009, 07:04 PM
  2. Compact Flash CF Freezes at XP Boot Screen
    By spudgunblunder in forum WinNT Based
    Last Post: 06-07-2007, 06:43 AM
  3. Lilliput 10.4 TS pink dots
    By scottw in forum LCD/Display
    Last Post: 01-07-2007, 06:01 PM
  4. Lost 12V power after rewire. Help!
    By SwapMeet in forum Car Audio
    Last Post: 11-29-2004, 11:19 AM
  5. 93 accord SE: The Lost Cause
    By fluffy2097 in forum Show off your project
    Last Post: 10-15-2003, 03:47 AM
