Results 1 to 2 of 2
Thread: Summarize FB Gauges in RR
    Newbie halestorm's Avatar
    Nov 2009
    Let me just see if I understand correctly how this works.
    First, I should say that what I want to do is make a set of custom gauges that live with the main menu buttons (I.E. not on a special "gauges" embedded screen). This is pretty much what Batman did last year. I could track his learning progress here but there were not a lot of details posted. So I'm running Ride Runner currently with the Simplistique skin (but anticipate modifying it a bit to fit my gauges) and I intend to buy the Fusion Brain (FB).
    Is it just a matter of using the RRFusion plugin and then the FB outputs just appear in RR as variables? Then I can use those variables as input to Flash scripts like these?
    Sorry if this is too basic but I just want to understand the fundamentals. I'm totally new to RR, FB, Flash, and even Windows (I'm a programmer by profession, just not in these areas).
    thanks,
    Dave
    http://www.evalbum.com/2500
    almost no reason to burn gasoline anymore
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You seem to have the right idea.. from flash you'd be executing the command fscommand("GETLABEL;ANALOG0RAW") and you'll have the flash variable ANALOG0RAW set in flash for you to use however you want..
    Ride Runner RR's Myspace
  1. Why do people think RR is hard to setup?
    By 2k1Toaster in forum Software & Software Development
    Last Post: 05-18-2008, 12:38 AM
  2. G Series Vans Look here. DASH GAUGES (BACKLIT)
    By ChevyG20SS in forum General Hardware Discussion
    Last Post: 09-12-2007, 02:12 AM
  3. RR Newb... need help/suggestions.
    By Nola111 in forum Road Runner
    Last Post: 03-12-2007, 07:10 PM
  4. RR Embedded IGuidance causes RR to lose focus
    By durwood in forum Road Runner
    Last Post: 11-10-2006, 09:31 AM
  5. Generalized Perception of RR from a new user
    By replicant in forum Road Runner
    Last Post: 11-15-2005, 10:41 PM
