Results 1 to 8 of 8
Thread: Delete folder command?
    Newbie Fuegomp3's Avatar
    Feb 2009
    Bs As, Argentina
    I search finding copy, paste commands, I found this thread
    copy, move, paste commands??
    But, I need delete folders, the coman "DELETEFILE" don work with folders, some options or command line? the idea is to delete a folder selected in the list (DL)
    Thanks in advance,
    Nelson.
    PD: I'm finishing my skin, in Spanish, soon I'll share with you, if anyone was interested in Spanish
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    you can do that with RUNQ but it's not as simple.. and I would HIGHLY recommend a popup confirmation if you implement it.
    Ride Runner RR's Myspace
    Feb 2009
    Bs As, Argentina
    Ok, something this?
    Code:
    Button with comand:
    "SETVARBYCODE;LISTTEXT;LISTTEXT||SETVARBYCODE;DLPATH;DLPATH||SETVAR;QUOTES;"||RUNQW;CMD.EXE|/C DEL $QUOTES$$DLPATH$$LISTTEXT$$QUOTES$$QUOTES$"
    I do not understand that it is "$quotes$"
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    The $quotes$ is setting a variable to contain the " (quote character). This is necessary, as if there are any spaces in the folder/file name, then it would not work without being surrounded in quotes.
    This is true for instance for folders such as "C:\program files\MyFile.zip"
    Thus it would need to be done like $quote$C:\program files\MyFile.zip$quote$
    My Fiero Build Thread
    Feb 2009
    Bs As, Argentina
    Thanks John, Im learning with this..
    Looking at the skin LSX void, I found a program called fileDELETE.EXE, I will try to get to work on my skin.
    But if anyone knows any other way, welcome.
    Thank you very much!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    For the quotes, you can actually put them in the command without any problem, but it may get confusing with the normal command quotes.
    For your RUNQW command, it seems fine, but you probably need to use del "/s" to delete a folder or it won't work. Using the EXE file should be easier though.
    Feb 2009
    Bs As, Argentina
    Ok, I will try and post here.
    Thanks,
    Feb 2009
    Bs As, Argentina
    Ok, I can't do work the commnad line, so, what I did was to install and embed the TOTAL COMMANDER, customize it a bit with the colors and font sizes, and look like this:
    With the skin I choose the disk on both columns, change the selected column, mark, copy and delete files or entire directories.
    Since I have no touchscreen, suchas a bit but it is easy to use.
    Greetings, and thanks for the help!
  1. CLDEL - Can't get this command to work
    By ThunderStick in forum Road Runner
    Last Post: 02-23-2009, 08:37 PM
  2. Delete song from harddrive via RR? is there a command?
    By sgtpepperaut in forum Road Runner
    Last Post: 02-08-2009, 05:55 AM
  3. Next Folder Command
    By skeeter007 in forum Road Runner
    Last Post: 01-05-2006, 01:07 PM
  4. How is RR passing command to MPC player?
    By civic5zigen in forum Road Runner
    Last Post: 11-23-2005, 02:26 PM
  5. Anyone understand Java ? I need help.
    By frodobaggins in forum Software & Software Development
    Last Post: 05-24-2004, 10:53 PM
