Code:
$WM_CAP_START = 0x400
$WM_CAP_UNICODE_START = $WM_CAP_START + 100
$WM_CAP_PAL_SAVEA = $WM_CAP_START + 81
$WM_CAP_PAL_SAVEW = $WM_CAP_UNICODE_START + 81
$WM_CAP_UNICODE_END = $WM_CAP_PAL_SAVEW
$WM_CAP_ABORT = $WM_CAP_START + 69
$WM_CAP_DLG_VIDEOCOMPRESSION = $WM_CAP_START + 46
$WM_CAP_DLG_VIDEODISPLAY = $WM_CAP_START + 43
$WM_CAP_DLG_VIDEOFORMAT = $WM_CAP_START + 41
$WM_CAP_DLG_VIDEOSOURCE = $WM_CAP_START + 42
$WM_CAP_DRIVER_CONNECT = $WM_CAP_START + 10
$WM_CAP_DRIVER_DISCONNECT = $WM_CAP_START + 11
$WM_CAP_DRIVER_GET_CAPS = $WM_CAP_START + 14
$WM_CAP_DRIVER_GET_NAMEA = $WM_CAP_START + 12
$WM_CAP_DRIVER_GET_NAMEW = $WM_CAP_UNICODE_START + 12
$WM_CAP_DRIVER_GET_VERSIONA = $WM_CAP_START + 13
$WM_CAP_DRIVER_GET_VERSIONW = $WM_CAP_UNICODE_START + 13
$WM_CAP_EDIT_COPY = $WM_CAP_START + 30
$WM_CAP_END = $WM_CAP_UNICODE_END
$WM_CAP_FILE_ALLOCATE = $WM_CAP_START + 22
$WM_CAP_FILE_GET_CAPTURE_FILEA = $WM_CAP_START + 21
$WM_CAP_FILE_GET_CAPTURE_FILEW = $WM_CAP_UNICODE_START + 21
$WM_CAP_FILE_SAVEASA = $WM_CAP_START + 23
$WM_CAP_FILE_SAVEASW = $WM_CAP_UNICODE_START + 23
$WM_CAP_FILE_SAVEDIBA = $WM_CAP_START + 25
$WM_CAP_FILE_SAVEDIBW = $WM_CAP_UNICODE_START + 25
$WM_CAP_FILE_SET_CAPTURE_FILEA = $WM_CAP_START + 20
$WM_CAP_FILE_SET_CAPTURE_FILEW = $WM_CAP_UNICODE_START + 20
$WM_CAP_FILE_SET_INFOCHUNK = $WM_CAP_START + 24
$WM_CAP_GET_AUDIOFORMAT = $WM_CAP_START + 36
$WM_CAP_GET_CAPSTREAMPTR = $WM_CAP_START + 1
$WM_CAP_GET_MCI_DEVICEA = $WM_CAP_START + 67
$WM_CAP_GET_MCI_DEVICEW = $WM_CAP_UNICODE_START + 67
$WM_CAP_GET_SEQUENCE_SETUP = $WM_CAP_START + 65
$WM_CAP_GET_STATUS = $WM_CAP_START + 54
$WM_CAP_GET_USER_DATA = $WM_CAP_START + 8
$WM_CAP_GET_VIDEOFORMAT = $WM_CAP_START + 44
$WM_CAP_GRAB_FRAME = $WM_CAP_START + 60
$WM_CAP_GRAB_FRAME_NOSTOP = $WM_CAP_START + 61
$WM_CAP_PAL_AUTOCREATE = $WM_CAP_START + 83
$WM_CAP_PAL_MANUALCREATE = $WM_CAP_START + 84
$WM_CAP_PAL_OPENA = $WM_CAP_START + 80
$WM_CAP_PAL_OPENW = $WM_CAP_UNICODE_START + 80
$WM_CAP_PAL_PASTE = $WM_CAP_START + 82
$WM_CAP_SEQUENCE = $WM_CAP_START + 62
$WM_CAP_SEQUENCE_NOFILE = $WM_CAP_START + 63
$WM_CAP_SET_AUDIOFORMAT = $WM_CAP_START + 35
$WM_CAP_SET_CALLBACK_CAPCONTROL = $WM_CAP_START + 85
$WM_CAP_SET_CALLBACK_ERRORA = $WM_CAP_START + 2
$WM_CAP_SET_CALLBACK_ERRORW = $WM_CAP_UNICODE_START + 2
$WM_CAP_SET_CALLBACK_FRAME = $WM_CAP_START + 5
$WM_CAP_SET_CALLBACK_STATUSA = $WM_CAP_START + 3
$WM_CAP_SET_CALLBACK_STATUSW = $WM_CAP_UNICODE_START + 3
$WM_CAP_SET_CALLBACK_VIDEOSTREAM = $WM_CAP_START + 6
$WM_CAP_SET_CALLBACK_WAVESTREAM = $WM_CAP_START + 7
$WM_CAP_SET_CALLBACK_YIELD = $WM_CAP_START + 4
$WM_CAP_SET_MCI_DEVICEA = $WM_CAP_START + 66
$WM_CAP_SET_MCI_DEVICEW = $WM_CAP_UNICODE_START + 66
$WM_CAP_SET_OVERLAY = $WM_CAP_START + 51
$WM_CAP_SET_PREVIEW = $WM_CAP_START + 50
$WM_CAP_SET_PREVIEWRATE = $WM_CAP_START + 52
$WM_CAP_SET_SCALE = $WM_CAP_START + 53
$WM_CAP_SET_SCROLL = $WM_CAP_START + 55
$WM_CAP_SET_SEQUENCE_SETUP = $WM_CAP_START + 64
$WM_CAP_SET_USER_DATA = $WM_CAP_START + 9
$WM_CAP_SET_VIDEOFORMAT = $WM_CAP_START + 45
$WM_CAP_SINGLE_FRAME = $WM_CAP_START + 72
$WM_CAP_SINGLE_FRAME_CLOSE = $WM_CAP_START + 71
$WM_CAP_SINGLE_FRAME_OPEN = $WM_CAP_START + 70
$WM_CAP_STOP = $WM_CAP_START + 68
#include <WindowsConstants.au3>
#include <GUIConstants.au3>
; Description: Main program
; Prepare the required Windows DLLs
$avi = DllOpen("avicap32.dll")
$user = DllOpen("user32.dll")
; Build the main window with the window title "RRMulti" to be used for embedding
$Main = GUICreate("RRMulti", 800, 600, -1, -1, BitOR($WS_MINIMIZEBOX, $WS_MAXIMIZEBOX, $WS_SIZEBOX))
; Create 4 capture windows, one for each camera
; Notes: 1. Windows can be added or removed as needed.
; 2. The WDM Capture Device is indicated in the $WM_CAP_DRIVER_CONNECT message for each capture window
; 3. The size and location of the capture area is set in the "capCreateCaptureWindow" DLL call
; 4. The script will run without cameras connected and will show 4 black capture areas
$cap0 = DllCall($avi, "int", "capCreateCaptureWindow", "str", "cap", "int", BitOR($WS_CHILD, $WS_VISIBLE), "int", 1, "int", 1, "int", 400, "int", 300, "hwnd", $Main, "int", 1)
DllCall($user, "int", "SendMessage", "hWnd", $cap0[0], "int", $WM_CAP_DRIVER_CONNECT, "int", 0, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap0[0], "int", $WM_CAP_SET_SCALE, "int", 1, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap0[0], "int", $WM_CAP_SET_OVERLAY, "int", 1, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap0[0], "int", $WM_CAP_SET_PREVIEW, "int", 1, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap0[0], "int", $WM_CAP_SET_PREVIEWRATE, "int", 1, "int", 0)
$cap1 = DllCall($avi, "int", "capCreateCaptureWindow", "str", "cap", "int", BitOR($WS_CHILD, $WS_VISIBLE), "int", 402, "int", 1, "int", 400, "int", 300, "hwnd", $Main, "int", 1)
DllCall($user, "int", "SendMessage", "hWnd", $cap1[0], "int", $WM_CAP_DRIVER_CONNECT, "int", 1, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap1[0], "int", $WM_CAP_SET_SCALE, "int", 1, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap1[0], "int", $WM_CAP_SET_OVERLAY, "int", 1, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap1[0], "int", $WM_CAP_SET_PREVIEW, "int", 1, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap1[0], "int", $WM_CAP_SET_PREVIEWRATE, "int", 1, "int", 0)
$cap2 = DllCall($avi, "int", "capCreateCaptureWindow", "str", "cap", "int", BitOR($WS_CHILD, $WS_VISIBLE), "int", 1, "int", 302, "int", 400, "int", 300, "hwnd", $Main, "int", 1)
DllCall($user, "int", "SendMessage", "hWnd", $cap2[0], "int", $WM_CAP_DRIVER_CONNECT, "int", 2, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap2[0], "int", $WM_CAP_SET_SCALE, "int", 1, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap2[0], "int", $WM_CAP_SET_OVERLAY, "int", 1, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap2[0], "int", $WM_CAP_SET_PREVIEW, "int", 1, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap2[0], "int", $WM_CAP_SET_PREVIEWRATE, "int", 1, "int", 0)
$cap3 = DllCall($avi, "int", "capCreateCaptureWindow", "str", "cap", "int", BitOR($WS_CHILD, $WS_VISIBLE), "int", 402, "int", 302, "int", 400, "int", 300, "hwnd", $Main, "int", 1)
DllCall($user, "int", "SendMessage", "hWnd", $cap3[0], "int", $WM_CAP_DRIVER_CONNECT, "int", 3, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap3[0], "int", $WM_CAP_SET_SCALE, "int", 1, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap3[0], "int", $WM_CAP_SET_OVERLAY, "int", 1, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap3[0], "int", $WM_CAP_SET_PREVIEW, "int", 1, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap3[0], "int", $WM_CAP_SET_PREVIEWRATE, "int", 1, "int", 0)
; Start the display
GUISetState(@SW_SHOW)
;HotKeySet("{INSERT}", "SnapShot"); Press 'Insert' to make a SnapShot !
; Process Windows messages, we only look at the Close event so the cameras can be disconnected
; Note: This routine can also handle messsages sent by other RR programs
While 1
$msg = GUIGetMsg()
If $msg = $GUI_EVENT_CLOSE Then
DllCall($user, "int", "SendMessage", "hWnd", $cap0[0], "int", $WM_CAP_END, "int", 0, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap0[0], "int", $WM_CAP_DRIVER_DISCONNECT, "int", 0, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap1[0], "int", $WM_CAP_END, "int", 0, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap1[0], "int", $WM_CAP_DRIVER_DISCONNECT, "int", 0, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap2[0], "int", $WM_CAP_END, "int", 0, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap2[0], "int", $WM_CAP_DRIVER_DISCONNECT, "int", 0, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap3[0], "int", $WM_CAP_END, "int", 0, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $cap3[0], "int", $WM_CAP_DRIVER_DISCONNECT, "int", 0, "int", 0)
DllClose($user)
Exit
EndIf
Sleep(1)
WEnd
; Description: Takes a snapshot
; Syntax: Snapshot($sFile, $sId)
; Parameter(s): $sId - Id ($cap{0-3}[0])
; $sFile - File to save the picture to (*.avi)
; Requirement(s): A webcam
; Return Value(s): On Success - Returns 1
; On Failure - Returns 0
; Author(s): Ludocus
; Note(s):
Func SnapShot($sFile, $sId)
DllCall($user, "int", "SendMessage", "hWnd", $sId, "int", $WM_CAP_GRAB_FRAME_NOSTOP, "int", 0, "int", 0)
DllCall($user, "int", "SendMessage", "hWnd", $sId, "int", $WM_CAP_FILE_SAVEDIBA, "int", 0, "str", $sFile)
EndFunc
; Description: Starts recording the webcam to a file
; Syntax: RecordStart($sFile, $sId)
; $sFile - File to save the movie to (*.avi)
; Note(s): Stop recording by: RecordStop($Id)
Func RecordStart($sFile, $sId)
DllCall($user, "int", "SendMessage", "hWnd", $sId, "int", $WM_CAP_FILE_SET_CAPTURE_FILEA, "int", 0, "str", $sFile)
DllCall($user, "int", "SendMessage", "hWnd", $sId, "int", $WM_CAP_SEQUENCE, "int", 0, "int", 0)
If @error Then
Return 0
Else
Return 1
EndIf
EndFunc
; Description: Stops recording.
; Syntax: RecordStop($sId)
; Note(s): None
Func RecordStop($sId)
DllCall($user, "int", "SendMessage", "hWnd", $sId, "int", $WM_CAP_STOP, "int", 0, "int", 0)
If @error Then
Return 0
Else
Return 1
EndIf
EndFunc
